Help with reorganizing and removing data from data element USING vb.net
 I'm exporting data from a PDF file in the following format:
 <?xml version="1.0" encoding="UTF-8"?>
 -<fields xmlns:xfdf="http://ns.adobe.com/xfdf-transition/">
 -<ListBox1 xfdf:original="ListBox1">
 <value>A-ItemA</Value>
 <value>B-ItemB</value>
 <value>C-ItemC</value>
 <value>D-ItemD</value>
 </ListBox1>
 <ItemType>A</ItemType>
 <Text111>data1</Text111>
 <TxtDate>data2</TxtDate>
 <TxtFT>data3</TxtFT>
 <TxtFuze>data4</TxtFuze>
 <TxtMT>data5</TxtMT>
 <TxtManu>data6</TxtManu>
 </fields>
 How do I rearrange the values in listbox1 and display only the First character in the data elements, as shown below?
<fields>
 <Lisbox1>A,B,C,D</Listbox1>
 </fields>
 Victor
vcharlesAsked:
Fernando SotoRetiredCommented:
Hi Victor;
This is almost like before.
Dim xdoc = XDocument.Load("From Path & Filename")
'' Get a reference to the ListBox1 node
Dim listBox = xdoc.Root.Element("ListBox1")
'' Remove the Attributes
listBox.RemoveAttributes()
'' Build the new value for the ListBox1 node
Dim listBoxValues = listBox.Elements().Select(vals => vals.Value.Substring(0,1)).Aggregate((workingValues, nextValue) => workingValues + "," + nextValue)
'' Remove all ListBox1 children nodes
listBox.Elements().Remove()
'' Add the new Value to the ListBox1 node
listBox.Value = listBoxValues;
'' Save the document
xdoc.Save("To Path & Filename")
vcharlesAuthor Commented:
I will try them later and get back to you.
Victor
They both work.
After the conversion, how do I replace
with
<fields>
Victor
To remove the attributes from the Root node you should be able to do this.
xdoc.Root.RemoveAttributes()
this should be done after opening the document.
.NET Programming
