Help with a Kohana ORM Validation problem
Hi All,
I'm having a problem using Kohana's ORM validation.  I've checked all over the web but can't seem to find an answer that addresses it.   Whenever I create a User model and run create_validate and then check() it gives me a result in the webpage errors that "Could not Validate Array", which is a bit less than helpful.  Just to give some background on it my register() function is:
UserAccount.php <- Controller
$user = new Model_User;
$post = $this->request->post();
$userparams = array();
$userparams[ 'first_name'] = $post[ 'FirstName' ];
$userparams[ 'last_name'] = $post['LastName']';
$userparams['password'] = $post['Password'];
$userparams['passconf'] = $post['PassConf'];
$usercheck = $user->validate_create( $userparams );
if( $usercheck->check() )
$user->values($userparams);
$user->save();
User.php <- Model
public function rules()
        return array
            'password'              => array
                array( 'not_empty', NULL ),
                array( 'min_length', array( ':value', 6 ) ),
                array( 'max_length', array( ':value', 128 ) )
            'passconf'              => array
                array( 'matches', array( ':validation', 'passconf', 'password' ) )
            'first_name'             => array
                array( 'not_empty' ),
                array( 'max_length', array( ':value', 45 ) ),
                array( 'regex', array( ':value', '/^[-\pL\pN_.]++$/uD') )
            'last_name'              => array
    public function validate_create( $array )
            $ruleArr = $this->rules();
        $array = Validation::factory( $array )
                ->rules( 'first_name', $ruleArr[ 'first_name' ] )
                ->rules( 'last_name', $ruleArr[ 'last_name' ] )
                ->rules( 'password', $ruleArr[ 'password' ] )
                ->rules( 'passconf', $ruleArr[ 'passconf' ] );
        return $array;
Sorry about putting all the code here, I thought it would be easier to look at the multiple classes without having to go back and forth between files.  Any questions let me know and I'll be happy to get any information.
Thanks in advance.
William-BAsked:
Terry WoodsConnect With a Mentor IT GuruCommented:
It looks like you should be using the "rule" method of the validation class, rather than "rules".
ie
                ->rule( 'first_name', $ruleArr[ 'first_name' ] )
                ->rule( 'last_name', $ruleArr[ 'last_name' ] )
                ->rule( 'password', $ruleArr[ 'password' ] )
                ->rule( 'passconf', $ruleArr[ 'passconf' ] );
Terry WoodsIT GuruCommented:
I don't know Kohana, but I googled it to see if I could help. One thing I noticed is that v3.0 uses Validate:factory and v3.2 uses Validation::factory
Is it possible you're using the wrong one? Which version are you using?
William-BAuthor Commented:
Thanks for your response.  I was using example code from Kohana 2.x and didn't realize that they removed the 's' from rules.  Now my array is ok but I'm getting an error saying:  Undefined offset: 1, which I have absolutely no idea what it means.  If anyone knows why that would be happening that would be great.  I've checked through all my Debug::vars outputs and everything seems to be correct.  Let me know if you need any other information.  Thanks again.
Do you get a line number and file with the error?
No it didn't give me that, but it happens inside the check() method.  I'm assuming that some of the data I'm passing is no good.  I'm going to track down the problem but since you solved my main problem, full points.  Thanks again.
