reference combo box on form problem specific column from a function call
Access 2010 vba.
Simply trying to reference a combo box on a form to get a value.  from a function call
' s2 = "BR2GCK"
      s2 = Forms!Form1![Combo5].Column(1)
ME keyword will not work in this case.
cant seem to get the syntax right
fordraiders
Fordraiders
Fordraiders
  • 2
Rey Obrero (Capricorn1)Commented:
is this giving you a problem
did you set the Column Count of the combo to at least 2
.Column(1)  refers to the 2nd column of the row source of the combo box.
FordraidersAuthor Commented:
brain lapse..
thanks
Learn to develop an Android App
Want to increase your earning potential in 2018? Pad your resume with app building experience. Learn how with this hands-on course.
  • 2
