Borders in body of spreadsheet overwriting double external borders - way to fix?
hi
I've got a customer with the following scenario..they have a spreadsheet with single lines on internal borders, and double lines on external borders.
They add new data and copy down the border information - the new single line border overwrites the external double line border and he has to use Format Painter to recreate the double external line..any suggestions?
agwalsh
agwalsh
  • 2
ProfessorJimJamCommented:
can u upload a sample?
agwalshAuthor Commented:
here it is..in the original it's fine. Then i copy down the data and the bottom border disappears.
borders-overwritten.xlsm
Rob HensonIT & Database AssistantCommented:
Insert a blank row at the bottom of the table and set the height to only a few pts. When new rows are inserted, ensure this row is selected before inserting. When the rows above are then copied/dragged down into the new rows make sure they don't go into the last row, the double border at the bottom will then stay.
Rob H
Did the job :-)
  • 2
