Solved
MVC 5 Separate Database Project and Web Project Connection String?
Posted on 2014-09-27
7
Last Modified: 2014-10-03
Q. Why do I still need to include the same Entity connection string the the Web Project web.config which is already used in the Database project's app.config?
Makes me wonder why the Database and Edmx is in a separate project within the same solution.
It seems that referencing the Database and using the following code would eliminate the need.
[Web Project Controller]
ProjectDB.ProjectEntities context = new ProjectDB.ProjectEntities ();
Question by:WorknHardr
  • 3
  • 3
7 Comments
LVL 85
Assisted Solution
by:David Johnson, CD, MVP
David Johnson, CD, MVP earned 1000 total points
because they are 2 distinct projects even though they may be in the same solution.
LVL 75
Accepted Solution
by:
käµfm³d   👽 earned 1000 total points
The database project is just a library. It's configuration is not read unless you read it yourself. The runtime will automatically load the connection string from the main application's configuration file. That is where your connection strings should go for execution.
Assisted Solution
by:WorknHardr
WorknHardr earned 0 total points
Understood, thx...
I have an unusual project request of moving both database and Models folder into a separate project. So I did and of coarse the main project failed to build. I then added Entity and Identity references to the database project. Now the main project build and runs like a normal mvc 5 web site should. Get this, I removed the connection strings from the main project web.config and it runs great. I further tested it with typical Entity/Linq CRUD and it works fantastic. So the only connection strings are in the database projects web.config. Unbelievable!
Below is a link I found:
http://blog.rebuildall.net/2013/10/22/Moving_ASP_NET_Identity_model_into_another_assembly
We value your feedback.
LVL 75
Expert Comment
by:käµfm³d 👽
OK, then maybe this is a feature of Entity Framework--in all of the (non-EF) projects I have worked on, it is as I mentioned above.
Author Comment
by:WorknHardr
Ooops, messed-up. Please don't close so I can reward points...
LVL 75
Expert Comment
by:käµfm³d 👽
You can "Request Attention" above.
Author Closing Comment
by:WorknHardr
thx
Concerto Cloud for Software Providers & ISVs
Can Concerto Cloud Services help you focus on evolving your application offerings, while delivering the best cloud experience to your customers? From DevOps to revenue models and customer support, the answer is yes!
Learn how Concerto can help you.
More often than not, we developers are confronted with a need: a need to make some kind of magic happen via code. Whether it is for a client, for the boss, or for our own personal projects, the need must be satisfied. Most of the time, the Framework…
International Data Corporation (IDC) prognosticates that before the current the year gets over disbursing on IT framework products to be sent in cloud environs will be $37.1B.
this video summaries big data hadoop online training demo (http://onlineitguru.com/big-data-hadoop-online-training-placement.html) , and covers basics in big data hadoop .
How can you see what you are working on when you want to see it while you to save a copy? Add a "Save As" icon to the Quick Access Toolbar, or QAT. That way, when you save a copy of a query, form, report, or other object you are modifying, you…
Suggested Courses
Course of the Month9 days, 23 hours left to enroll
571 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
