Power over ethernet - Any loss of speed, etc???
I need to get a network switch and I am considering a 4/5 port switch that get it's power from the ethernet cable. i.e power over ethernet. I was just wondering if there is any disadvantages of this when compared to a main powered switch? Any lose of speed, etc? It's just a home network so no high demands.
petewinterAsked:
Lee W, MVPTechnology and Business Process AdvisorCommented:
There's no point in spending the extra money UNLESS you have a device that uses PoE.  Do you?  In general, they are used with phones... perhaps wireless access points.  But otherwise, very few items will make use of it, especially in a home network.
That said, there should be no noticeable difference in performance.
petewinterAuthor Commented:
Thanks for the reply. Oh I think I have this confused. I was thinking the actual switch would not need a main supply. i.e. It would get it's power from the joining ethernet cable. Does that mean if the switch has PoE it's talking about the port that come out of it?
akbCommented:
Yes. The switch will still need mains power. Also, POE uses some of the wires which means most POE devices are limited to 100GB as GB ethernet uses all 8 wires. There are devices which allow GB and POE but these are more expensive.
SolarWinds® Network Configuration Manager (NCM)
SolarWinds® Network Configuration Manager brings structure and peace of mind to configuration management. Bulk config deployment, automatic backups, change detection, vulnerability assessments, and config change templates reduce the time needed for repetitive tasks.
Thanks, but what do you mean by GB and POE? No reduction in speed?
Strictly speaking, akb is mis-.... labeling?  GB = Gigabyte, akb really means Gb, which means Gigabit.
POE / PoE means Power Over Ethernet.  It's where the switch provides power to device on the network so they they don't need their own power cables.  The switch itself needs power.
I have a client who has phones that are PoE - they are more like older phones in that they ONLY have a network cable plugged in to them, no power cable/power brick because the switch provides the power for the phone (similar to the old phone system which provided power to the phones in the old days in most homes).  The same client has a wireless access point (like a wireless router, but no router capability, it just provides wireless) that gets it's power through the network as well - it's sitting in a drop ceiling with no power cables, just the ethernet cable connecting it and powering it.
Based on your comment to my response before, I agree - I think you were confused.  Neat idea though... but as far as I know, know switch exists that gets power from the network cables as no network adapters provide power over ethernet TO the switch.
akbCommented:
GB is gigabit - 1000mb.
POE is Power Over Ethernet.
In my comment I meant 100mb (megabit), not 100GB.
JustInCaseCommented:
I'm not sure if I understood question good.
You want to buy switch powered by POE. There is no loss of speed, BUT you still need POE injector to power up switch (it can be more expensive). This kind of switch is usually used on places where you don't have electric plug - attic, roof etc. If this is not case, there is no gain from buying that kind of switch (except you already have some POE device to power up that switch).
Or I have missed my point completely. :)
Many thanks for your help and advice. I assume that if I have not power I just need to use a ethernet splitter and that will share the speed.
Switches / Hubs
