Avatar of 1badscamper
1badscamper
Cisco Aironet 1552e-a-k9 & Power Injector Cable Help
Hello Experts,
Thanks in advance for the help. I have a Cisco Aironet 1552e-a-k9 That will be powered by a cisco power injector "AIR-PWRINJ1500-2. The AP will be pole mounted
outside our building, The power injector will be in the Computer room. My Part in this Job is to get all hardware ready for now. I was supplied all the cable and hardware from a 3 party vendor. I was reading the specs for the cable and it seems
I need shielded 26 AWG for the power Injector(ONLY) according to the cisco directions. The directions do not give any wiggle room on the cable.  I was supplied non shielded Indoor/outdoor 24 awg cat 6 Jelly filled cable.
  Before you ask, Yes I do have a surge gate Between AP and the power Injector.
My Question is what Kind of cable is best for this? What does everybody else use with a power injector? If I used the cable they gave me I think I might be looking at problems. Any Help would be Great.
Chris
Wireless NetworkingNetworking Hardware-OtherComponents
1badscamper
Craig Beck
1badscamper
Thanks Craig, Cisco left out the "OR BETTER" in the manual. I ended up with a 1000' roll of unshielded cable I cant use now. Go Figure. One more quick question, Because this will be outside, Is is correct I should be using the Jelly filled cable? Any Recommendations, I have 3 buildings I have to do,  Also I have been thinking about using the hole for the fiber connection that we will not be using for a permanent connection for the console cable, it would be a bummer having to go on a roof with a laptop and hook in that way, You see any problems with doing it like that?
Thanks Chris
William Peck
