Avatar of Sanjay
Sanjay
sql script help in using case statment with a select statement
i am new to sql scripting.  Basically all I am trying to do is to output one column called 'Rev' based on the two case statements below.  The scripting works for the most part.  The only problem is that it outputs two columns called 'Rev'.  i just need one column.  So if the first case statement condition is not found, then move to the second case condition etc.
DECLARE @FullName   VARCHAR(100)
SET @FullName = '07000496_C.F2'
SELECT
            case when @FullName like '%_%' and @FullName not like '%.%' then SUBSTRING(@FullName, CHARINDEX('_', @FullName) + 1, LEN(@FullName)) end AS Rev,
            case when @FullName like '%_%' and @FullName like '%.%' then SUBSTRING(@FullName, CHARINDEX('.', @FullName) + 1, LEN(@FullName)) end AS Rev
Thank you.
Microsoft SQL Server 2008SQL
Simon
Simon
Jim Horn
CASE statements support multiple WHEN .. THEN statements, where SQL executions them sequentially until one WHEN expression evaluates to True, then returns what's in the THEN.
SELECT CASE
  WHEN @FullName like '%_%' and @FullName not like '%.%'
      THEN SUBSTRING(@FullName, CHARINDEX('_', @FullName) + 1, LEN(@FullName))
  WHEN @FullName like '%_%' and @FullName like '%.%'
      THEN SUBSTRING(@FullName, CHARINDEX('.', @FullName) + 1, LEN(@FullName))
  END AS Rev
I have an article out there called SQL Server CASE Statments that illustrates multiple WHEN..THEN, nested statements, and many other features of CASE statements.   If it helps please click the big green 'Was this article helpful?' button at the end of the article.
Vitor Montalvão
You just need a CASE statement:
SELECT case
    end AS Rev
Vitor Montalvão
Damn. I knew I should refresh the page before clicking in the Submit button!
William Peck
Simon
Also underscore is a wildcard character. You should use [_] to represent the literal.
Sanjay
Thank you everyone.  Much appreciated.
Jim Horn
<Frazier Crane>  When you know the answer it's hard not to hit the button..
Simon
Final version with [ and ] around the underscore (otherwise LIKE treats it as a wildcard representing any single character):
SELECT
            case when @FullName like '%[_]%' and @FullName not like '%.%' then SUBSTRING(@FullName, CHARINDEX('_', @FullName) + 1, LEN(@FullName))
             when @FullName like '%[_]%' and @FullName like '%.%' then SUBSTRING(@FullName, CHARINDEX('.', @FullName) + 1, LEN(@FullName))
else  -- if you omit this you would get NULL by default for unmatched cases
'n/a'
end AS Rev
MSDN reference for the LIKE operator
