Tom
Dreambox DM600 Hardware problem, blown power to LNB
Dreambox DM600 has blown power to LNB.
Can anyone help with schematic, service manual or parts to check?
Are you sure it is not cable in between?
Yes I'm sure. No DC voltage on antenna connector on DM600
LNB was damaged and was drawing to much current, thereby blowing the DC regulator on DM600
Have seen similar failure on Dreambox DM500 and the problem was blown transistor on motherboard. Unfortunately the DM600 has not the same motherboard layout.
You can power the receiver head via aplitter (provided receive circut is not blown in the box)
Yes you can, but the problem is that the DC voltage is used for polarization of the LNB, and for power to the LNB. So a vertical channel will have a different voltage level than a horizontal channel.
So in theory you will need a switch with 2 voltage levels and each time you swap the channels on your remote
you must flip the switch depending if it is a horizontal or vertical channel you are watching :-)
Yes, or you buy a new dreambox instead.
I could not find any internal diagrams of new dreamboxes past DB400 :S
With many years in the hardware field it will be hard to give this project up. :-)
And yes I have already a new DM800HD installed.
For sure the schematic is available somewhere as you have plenty Dreambox clones around.
you are the master.
Together we are unbeatable :-)
