Buddy
Win-7 Pro Problem with Shutdown/Restart takes 5-10 minutes, then power Off and restart. Forced Restart Required
Cannot cleanly Shutdown or Restart -- Must restart from power off/on
Noticed in Registry HKLM/Software/Microsoft/Wi ndows/Curr ent Version/Component Based Servicing/Sessions Pending/ ...
many rows of various components with similar dated entries, e.g., 1_Shutdown Finished value "2014/11/20 03:28:09" or Start Up entries various date/times in Late November. Would this indicate that the component services are unable to complete? If so, How can this be corrected? Can certain registry entries be deleted to force cleanup? I use Advanced Systems Care Pro to keep Registry Clean and defragged
you can try a system restore to a date it was ok
you can also run sfc : http://www.sevenforums.com/tutorials/1538-sfc-scannow-command-system-file-checker.html
and as said get rid of Advanced Systems Care Pro and similar
also check in installed programs from control panel if there is no software that you can uninstall, because it is unknown, or not used + all toolbars
if unsure post the list of installed programs - or a screenshot
Thanks David
Sorry to be so slow on response. Had other priorities and lacked access. This cleaned up most issues, but I also had a lot of overhead in my display settings (run two monitors) Two different size resolutions 1440 x 900 and 1920 x 1080 - had to adjust advanced browser setting to reduce overhead.
I think that's where the problem started.
Leave the registry alone. You're asking for trouble by using a registry "cleaner".
