aggregated numbers do not match between sql 2005 cube and sql 2008 cube
I took a backup of the relational database from sql 2005 and restored it to sql 2008 r2.
Now I created a cube on sql 2008 r2 and created same measures and dimensions as they were on the cube on sql 2005.
When I browse the two cubes using the same dimension and measures, I get different numbers on the two cubes.
When I run a sql query to calculate sum on a fact table on both databases, the results match perfectly and they match to the results on sql2005 cube, but sql 2008 R2 cube numbers are way low.
There are no calculations set for this measure on any of the cubes.
I have checked on both cubes. The source, AggregateFunction, DataType, FormatString etc are the same for the measure on bot cubes.
What else can be causing this difference in numbers? What do I need to check?
Thanks.
patd1
patd1
LIONKINGCommented:
Check the security settings of the account you're using to browse the cube. Also, check that all the dimensions that exist in the first cube, exist in your 2008 cube + that they all contain the same members (i.e. their source tables are identical and they are fully processed with all the members).
If you really want to know what's wrong, you can remove all the dimensions, leave only one, deploy and test. If the numbers are good, you know that the problem is with one of the dimensions, so start adding them gradually until you find the one that's causing the issue.
patd1Author Commented:
it was not the permissions. I deleted all roles and processed and browsed again, with no improvement. I still have to delete dimensions one by one and process each time to see if that helps identify the problem, but that is a lot of work. I think there should be a better way.
Become an Android App Developer
Ready to kick start your career in 2018? Learn how to build an Android app in January’s Course of the Month and open the door to new opportunities.
