Cisco 2504 wireless lan contoller not providing DHCP to wired lan
I have purchased my first cisco 2504 wireless lan controller that links into two Netgear managed switches. One switch is a GS728TP using POE for 15 AP's and the other switch is a Netgear GS748TP for a hard wired network. I am using the inbuilt DHCP server on the Cisco 2504 which is working fine for the wireless network but none of the wired clients are receiving IP addresses. I do not have any other means of supplying DHCP. Can anyone advise why this is - thanks in advance.
VBOSSAsked:
bill30Connect With a Mentor Commented:
He did, its not possible:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-0/configuration/guide/c70/c70wlan.html#wp1108971
Note: A internal DHCP server pool will only serve the wireless clients of that controller, not clients of other controllers. Also, internal DHCP server can only serve wireless clients and not wired clients.
If you have a PC that is wired and always connected you could throw TFTP64 on it and use the DHCP server function.  Or use some other open source DHCP if a router or full blown DHCP server is not an option.
http://download.cnet.com/Tftpd32-64-bit/3000-2085_4-75446930.html
John HurstConnect With a Mentor Business Consultant (Owner)Commented:
That wireless device has 3 Ethernet ports. When you connect directly to one of these ports, do you get an IP address?
AkinsdConnect With a Mentor Network AdministratorCommented:
1st, can you ping the controller from the switch
2nd, have you configured ip helper-address pointing to the 2504 ip address.
eg int vlan 1
ip helper-address 192.168.1.200
SMB Security Just Got a Layer Stronger
WatchGuard acquires Percipient Networks to extend protection to the DNS layer, further increasing the value of Total Security Suite.  Learn more about what this means for you and how you can improve your security with WatchGuard today!
Craig BeckConnect With a Mentor Commented:
@John - The 2504 has 4 ports :-)
@VBOSS - The WLC can't do DHCP for wired clients unless you're using the wired guest feature.  You won't be doing that for a standard WLAN, so you'll need to use the router or proper DHCP server for wired clients.
John HurstBusiness Consultant (Owner)Commented:
I will let you solve this.
VBOSSAuthor Commented:
In the end i added a hp micro server with windows server and dhcp. Thanks all for your contributions.
Craig BeckCommented:
Thanks, but i think my comment was 'the answer'.
