2850 - Memory/Battery Problems Were Detected
No time to determine which one was bad, so took battery, memory, and key from duplicate server and swapped out. Bought all three parts as a kit. Now, I have the three from the old (original with error) and then three new. Do I take the replacement server (the server I used to pull working parts from) and put in the parts individually to see what was actually wrong or do I just put all three new parts (new/used) at one time?
I have done this before with the same type of server, Dell PE 2850 Perc 4e/Di. When I did I tried individual parts but eventually had to replace all three before it was working again. Some say all at once and some say individually.
Thoughts?
JenniferIT DirectorAsked:
PowerEdgeTechConnect With a Mentor IT ConsultantCommented:
Start with memory (make sure it is good). If you get this on every boot and the LCD screen is not showing a batt/volt error, then 99/100 times it s the memory.
Aside from replacing all three, the riser can also be the cause (memory slot).
JenniferIT DirectorAuthor Commented:
Thanks. I went ahead and put in all three since the machine I was putting all three in was not the machine that was throwing the error to begin with. I was really hurt on time and went for all in one.
Thank you for the input though.
