how to connect 8-pin power supply to a 6-pin graphic card
Posted on 2015-02-22
Last Modified: 2015-03-13
Hi experts,
I have a question on how to connect the psu power connector to a graphic card power connector.
The graphic card is xfx R7 260X. It has a 6-pin PCI-E power connector.
My psu is Seasonic 620GM. I used up other power supply and only has a 8-pin power connector left.
I first thought I may just need an adaptor from 6-pin to 8-pin, then it should work. Then I read some articles on the web and seem that there are more than that.
And I see specifically in the warning that come with the graphic card that "The 8-pin PCI-E power connector is not the same as the 8-pin CPU power connector. Please ensure you connect the correct one."
So, now I have a second though and double that if the 6-pin to 8-pin adaptor can solve the problem.
Please help.
Question by:ResourcefulDB
  • 3
  • 2
LVL 41
Expert Comment
As I can see on seasonic site:
this PSU has 6-pin connector, so you should only find proper connector (PCI-E 6P, should be in a standard PSU set) and connect it
Author Comment
@als315: Thanks, after the previous post, I took down the psu from the case and do see the 6-pin connector. I will look for a cable connect directly from psu to the graphic card.
Next thing I notice is that both the psu and gpu have 6-pin male connector build in. So, we will need a female to female 6-pin cable to connect them. It seems that all the extension cable has one end as male, the other end as female.
Am I on the right track?
I do not see anything that has female at both ends.
LVL 41
Expert Comment
Special cable PSU-GPU was included into the PSU set of cables. Try to find it. Did you install PSU yourself?
We Need Your Input!
WatchGuard is currently running a beta program for our new macOS Host Sensor for our Threat Detection and Response service. We're looking for more macOS users to help provide insight and feedback to help us make the product even better. Please sign up for our beta program today!
Author Comment
@als315, yes, I installed psu long time ago. Cannot remember if there was other cable I did not use and could not find anything in my tool box where I usually keep my extra accessories.
I looked at my psu again. Referring to the seasonic picture in your previous link, only two output slots from the psu was used. They are both at the right side of the picture. So, both PCIE 6P slots are available.
Yes, I need to find those special cable. If not, where do we buy them?
LVL 33
Expert Comment
by:Predrag Jovic
Be extra careful when you purchase/buy those cables since there's no standardization for plug entering PSU (as much as I know).
You can kill your graphic card if you get wrong cable. So far I know for two cases of wrong cables and dead equipment.
I think it is much safer to go for 5.25" Molex to PCI Express Graphics Card 6pin Power Cable Plug, in case that you have two free molex plugs. But, try to find your original cables if you can, PSU rails will have less load, and that will prolong PSU lifetime.
LVL 41
Accepted Solution
als315 earned 2000 total points
WEBINAR: GDPR Implemented - Tips & Lessons Learned
Join the WatchGuard team on Thursday, March 29th as we recount some valuable lessons learned in weighing the needs of a business against the new regulatory environment, look ahead at the two months left before implementation, and help you understand the steps you can take today!
Join & Write a Comment
What do we know about Legacy Video Conferencing? - Full IT support needed! - Complicated systems at outrageous prices! - Intense training required! Highfive believes we need to embrace a new alternative.
In the modern office, employees tend to move around the workplace a lot more freely. Conferences, collaborative groups, flexible seating and working from home require a new level of mobility. Technology has not only changed the behavior and the expe…
Did you know PowerShell can save you time with SaaS platforms? Simply leverage RESTfulAPIs to build your own PowerShell modules. These will kill repetitive tickets and tabs, using the command Invoke-RestMethod. Tune into this webinar to learn how…
624 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
