rdefino
Need power shell script to move a system to 1 of 3 OU's based on a registry entry
I need to come up with a script that will look at a registry entry on a system and based on that setting the script will move the system to 1 of 3 ou's.
Any thoughts on how to do this. It's above my abilities to script.
thanks
thanks
Which registry entry are you going to key off of and do you already have a script that will move a system into a specified OU (without making any comparisons that is)?
I don't have the keys yet, but I have a script I've used to moves systems. How would I reference a reg key from the script?
import-module ac*
gc e:\scripts\move_systems_to _ou\pclist .txt | % {
Get-ADComputer $_| Move-ADObject -TargetPath "New_OU"
import-module ac*
