Query called running LINQ times out when same Query running in Management Studio completes in about 4 seconds.
I have a stored procedure in my MS SQL SERVER 2012 database that is called using LINQ (.NET 4.5) to populate a scheduler control.
The query completes in about 4 seconds normally both for the application calling it via LINQ and running the same query using management studio.
PROBLEM: Every few weeks the application starts timing out on that query when called using LINQ. Query runs fine via management studio.
I can fix the issue by essentially altering the SQL of the stored procedure and then altering it back to the original SQL. Then the query runs fine using LINQ again.
Any ideas what would cause this where a query gets executed differently from LINQ than it does using management studio?
LVL 2
YMartinAsked:
Snarf0001Commented:
You're probably falling victim to parameter sniffing.  Basically the system "guesses" at the best execution plan, and sometimes caches a bad one.
When you hit it from mgmt. studio, it seems to refresh the plan and run with that one.
http://blogs.technet.com/b/mdegre/archive/2012/03/19/what-is-parameter-sniffing.aspx
Fernando SotoRetiredCommented:
Hi YMartin;
You state the following, "I have a stored procedure in my MS SQL SERVER 2012 database that is called using LINQ", and then you state this, "I can fix the issue by essentially altering the SQL of the stored procedure and then altering it back to the original SQL. ", Linq to SQL or Linq to Entity Framework does not build the query it only sends a command for the SQL server to execute a stored procedure which is defined in SQL server. All that Linq is doing is sending a command and the command is actually being sent by ADO.Net which Linq sits on top of and communicate with the server and is mature product.  Seeming that the issue gets corrected when making some changes on the server I would look at the server end.
Anthony PerkinsCommented:
Why don't you start by posting the query and all relevant schemas?
Vitor MontalvãoMSSQL Senior EngineerCommented:
YMartin, do you still need help with this question?
Microsoft SQL Server
