Mike_Stevens
Problem using Select Case with nested loops using vb.net
I am working on a project that requires some looping predetermined number of times. Within the For Next Loop I am trying to use Select Case to read string values until a certain condition is met. Below is my code and hopefully an understandable description of what my problem is:
To simply the example I will explain what happens within the do while loop...... A text file is broken down line by line and then each line is broken into “segments” using the split function. Using Select Case I am reading the first “Segment” of line to determine if a specific value is contained in the “segment”
xx = 10 Value of xx is determine earlier in the code
For k = 1 To xx
xDone = False
Do While xDone = False
Select Case xSeg(0)
Case Is = “ABC”
‘Then do something and continue on
Case Is = “DEF”
Case is = “XYZ”
xDone = ‘True’ Indicate condition was met
'Condition met...move on
End Select
Code --- > ‘If xDone is still false then move to next line of data and break into segments and start process again,
Loop
When the ‘xDone’ condition has been met and xDone = True the Do While Loop should exit back into the for next loop at the .
Next k
The problem I am having is that this process should run ten times as indicated in the for (For k = 1 To xx ) next but it only will run a maximum of three times. Sometimes the data that is being process requires that the For Next should only loop once or twice or sometimes more but it will only loop a maximum of three times.
It has something to do with the Select Case because if I remove that whole section of the code everything works fine.
Im not a vb.net expert and I cant figure it out on my own. Any help would be appreciated.
For k = 1 To xx
xDone = False
Select Case xSeg(0)
Case Is = “ABC”
Case Is = “DEF”
Case is = “XYZ”
End Select
Loop
Next k
The value of K is being modified as it should and gets to three and that's when for next look gets exited. It should go to 10
The value of K is being modified by what, the for next will modify (increment it anyway). As James has said there are better tools to exit a loop than by modifying the loop counter within the loop.
What is the code that is modifying the value of k?
You could put a debug line at the top and bottom of the for loop to print the current value of k
this will tell you if the value is being modified during the execution of the loop
