Cisco WC 2504 speed issue max 54mbps
recently we purchase cisco wireless controller 2504 and Air -CAP2702I-D-K9 access point and setup it properly as per below link instructions. but we are not able to get more than 54 mbps speed when using  8.1.102.0 IOS with latest version of  cisco 2702 series  802.11ac support access point.
kindly help on this.
http://www.hackandsecure.com/2014/09/18/basic-wireless-lan-controller-configuration/,
sitgAsked:
Craig BeckCommented:
You need to disable TKIP and use AES as the only encryption method.
TKIP doesn't support 802.11n or 802.11ac.
sitgAuthor Commented:
but still I getting max 70 mbps speed, any other way to increase the speed ?
Naresh
Is 70Mbps what the NIC tells you you're connected at, or what you get while doing a speed test?
StolsieCommented:
are your devies connecting at 5 or 2.4?
Wireless Networking
