operationsIT
What is the best way to cable 2 - 3750 switches power stack cables
Hello EE,
We have 2 3750 units we are bringing up in a stack.
This is the first time I've seen the power stack cables so am I going to do switch 1 power 1 to power 2 on switch 2?
What is the best approach
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/12-2_53_se/configuration/guide/3750xscg/swstkpwr.html#wp1015591
Both cables are not required, but should provide tolerance to failure of cable, port, or an admin who disables a port or pulls a cable accidentally.
I think you can also connect ports 1>2 and 2>1 and it should behave the same.
Does going from Sw1 Port1 > Sw2 Port1 and Sw1 Port2 > Sw2 Port2
offer any benefits over going from ports 1>2 and 2>1?
It appears power-sharing is default what would be the benefit of changing to mode redundant?
Sw1# stack-power switch 1 port 1 enable
Sw1# stack-power switch 1 port 2 enable
Sw1# stack-power switch 2 port 1 enable
Sw1# stack-power switch 2 port 2 enable
Sw1# stack-power stack POWERSTACK-A
Sw1(config-stackpower)# mode redundant
Sw1(config-stackpower)# exit
Sw1(config-switch-stackpow
There are more options for priority and power shedding you can find here:
