David Glover
How to alter this REGEX pattern to match whole words rather than parts?
So in this example, the word man is found in amongst HTML markup.
(MAN)(?=[^>]*<)
It is matched ok but it also matches for occurrences in the HTML of MANAGEMENT or GERMANY etc. It isn't as easy as saying I want to see a space on each side either since punctuation and non alpha numeric characters would be acceptable.
How can I enhance the pattern so that alpha numeric characters preceding or following prevent matching?
Thanks!
(MAN)(?=[^>]*<)
Thanks!
Try this pattern: ([^a-z\b0-9]?)(MAN)([^a-z\ b0-9]?).
I tried it with man but sadly it did not work.
([^a-z\b0-9]?)(man)([^a-z\ b0-9]?)
but unfortunately this matched man in 'germany' and other words.
My code adds ( ) and (?=[^>]*<) to your expression to filter HTML to become
(([^a-z\b0-9]?)(man)([^a-z \b0-9]?))( ?=[^>]*<)
Would this have broken it?
Sorry I forgot about the case sensitive when copy paste here. This is the best pattern that I can think of (and already checked): (([^a-zA-Z]+)|(\b))(MAN)(( [^>a-zA-Z] )|(\b))
Hope it could help.
Hope it could help.
Thanks Ozo that worked fine!
