Looking for a document scanner with networking (not wireless) for $500 or less. Ideally $300 or less if possible.
Client is looking for a scanner that they can save documents to networked PCs.  They don't want to spend over $500 dollars though and they'd ideally like something for around $300.  Any suggestions would be welcome.  I sent them a quote for the brother ADS2500WE but it's out of their price range.
B19SupportAsked:
Michael MachieFull-time technical multi-taskerCommented:
HP OfficeJet 8600 All-in-One. About $150.
Allows scan to PC from a button as well as Scan to Network Share. Not the fastest, but has a doc feeder and a wired ethernet port. Is is not a dedicated scanner but has those functions.
The next would be to look at a Fujitsu in that price range..
Joe Winograd, Fellow&MVEDeveloperCommented:
If you really like the Brother ADS-2500We, its street price is close to $500 — currently $533 at Amazon:
http://www.amazon.com/Brother-ADS2500WE-Document-Scanner/dp/B00OS99PYG/
Also, Brother makes numerous network-wired MFCs that are under $500. Since your client will be using it for scanning only, you may as well go with a B&W laser printing unit, not a color one. Here's a link to all of the Brother B&W laser MFCs:
http://www.brother-usa.com/MFC/BW_Monochrome_Laser_Multifunction/
This list has several MFCs with a wired (Ethernet) connection and a street price under $500 — some under $300 (Amazon is a good place to check for street price). Btw, you may be tempted to save some money by getting an MFC with inkjet (instead of laser) printing – don't! Even though your client won't be printing with it, do not go for an inkjet model — they burn through printer cartridges even when not printing. The cleaning cycle is the culprit (not an issue on the lasers). On some of the inkjets, you can scan without a printing cartridge even being present — on others, you can't. It's not worth the price difference — get a B&W laser. Regards, Joe
P.S. Re the previous post, Fujitsu does not have a network scanner that is in your price range (neither does Kodak). The only current production Fujitsu network scanners are the fi-6010N and N1800, both of which are way beyond your price range.
B19SupportAuthor Commented:
It would be nearly impossible to get a more concise and informative, answer.  In fact, this answer perfectly matches the definition of concise. I was not only given an answer but an explanation to why it was the answer.  I was then given the answers to questions I didn't even know I should be asking.  If only all the questions in my life were answered in such an easy to understand way with such clarity and freely given guidance.
Thank you for taking the time to post those very kind words — nice to hear! Regards, Joe
Peripherals
