Akash Bansal
Need a Power (UPS) Management software compatible with USB enabled UPS
I am looking for another UPS management software that can shut down the server gracefully before battery gets drain out & fire an email alert.
Currently I am using viewpower UPS management software:
http://www.power-software-download.com/viewpower.html based on tomcat & java.
Currently using the following 1KVA UPS model:
http://www.emersonnetworkpower.com/en-IN/Products/ACPower/DesktopWorkstationUPS/Pages/LiebertGXTMT+1-3kVAOnlineUPS.aspx & http://microtekdirect.com/online_ups_max_series.php
The UPS is connected through USB cable with single physical IBM server. Server is having SBS 2011 installed.
The current software gets corrupted very frequently in case server booted due to power failure and battery drains out before server gets shutdown gracefully. I have to reinstall the software to re detect the usb connection of the UPS.
Please guide.
Please guide.
Thanks Wayne88 for sharing the links.
The software downloaded from first link is asking PRTK code written on UPS label.
What I need to enter?
Got these VID & PID from the device manager. both of the UPS have the same PID & VID.
vid_0665 pid_5161
The following software recognised my UPS but did not able to install the driver:
http://www.networkupstools.org/package/windows/NUT-Installer-2.6.5-6.msi
The driver was created by http://sourceforge.net/projects/libusb-win32/files/libusb-win32-releases
but the driver did not work with any other monitoring software.
This is the nice small software that recognised my UPS but lag many power features:
http://sourceforge.net/projects/winmust/files/winmust/0.4.2.2/
So till now I could not get the solution, back to viewpower.
vid_0665 pid_5161
I have switched to APC BPE edition of UPS management software.
Moreover IBm servers' USB port creates issue with all UPS USB port, so installed add on PCI-X USB card & got resolved the issue completely.
I got solution myself:
http://www.ups-technet.com/upsmon.htm
Here is another one http://www.ups-software-download.com/
