Need Java help: System.out.println, System.out.print and System.out.format
I need three different columns displaying information as follows in the screenshot. They should contain different values for number of times cpu has been accessed.
Here is the code I have so far, which displays only one column:
public class JRoundRobin
    public static void main(String[] Me)
        int N[] = new int[28];
        int M[] = new int[28];
        int P[] = new int[28];
 		int k;
 		boolean IsItFilled;
		N[25] = 0; // cpu eaten
		M[25] = 0; // cpu eaten
		P[25] = 0; // cpu eaten
        N[24] = 50; // cpu time allotted
        M[24] = 50; // cpu time allotted
        P[24] = 50; // cpu time allotted
		N[26] = 0; // index filled
		M[26] = 0; // index filled
		P[26] = 0; // index filled
		N[27] = 0; // #times called
		M[27] = 0; // #times called
		P[27] = 0; // #times called
		N[23] =   100; // start number of smallest
		M[23] =  1000; // start number of smallest
		P[23] = 10000; // start number of smallest
		N[22] = 0;  // start number of biggest
		M[22] = 0;  // start number of biggest
		P[22] = 0;  // start number of biggest
		N[20] = 0;  // start number of sum
		M[20] = 0;  // start number of sum
		P[20] = 0;  // start number of sum
		for ( k = 0; k < 20; k++)
				N[k] = 0;
				M[k] = 0;
				P[k] = 0;
		IsItFilled = true;
		while (IsItFilled)
						PopulateTheNArray(N);
						if (N[19] != 0 )
							IsItFilled = false;
			GetSumForN(N);
			GetAverageForN(N);
			GetBiggestForN(N);
			GetSmallestForN(N);
			GetCPUTimeAllotedForN(N);
			for ( k = 0; k < 28; k++)
				System.out.println("\n\t\tArray: N[" + k + "] = " + N[k]);
		//PopulateTheMArray(N);
		//PopulateThePArray(N);
	}	// end of domain of public static void main
   		// domain of the methods
	public static void PopulateTheNArray( int []Q)
       long StartTime,EndTime;
       int k,IndexFilled,Holder;
       StartTime    = 0;
       EndTime      = 0;
       IndexFilled  = 0;
       StartTime = System.currentTimeMillis();
       for (k = 0; k < 20; k++)
		   if ( Q[k] == 0 )
				IndexFilled = k;
				k = 21;
	   k = IndexFilled;
	   while ( k < 20 )
		   Holder = (int)(Math.random()*1000);
		   if ( Holder > 9 && Holder < 100 && Holder % 2 == 0 )
	   			Q[k] = Holder;
	   			EndTime = System.currentTimeMillis();
	   			k++;
			if ( (int)(EndTime - StartTime) > Q[24] )
					k = 21;
	   Q[27] +=1;
		public static void GetSumForN( int []Q)
			int k;
					Q[20] += Q[k];
		public static void GetAverageForN(int []Q)
			Q[21] = Q[20]/20;
		public static void GetBiggestForN(int []Q)
				int k;
						if ( Q[k] > Q[22] ) Q[22] = Q[k];
		public static void GetSmallestForN(int []Q)
				int k;
				for ( k = 0; k < 20; k ++ )
					if ( Q[k] < Q[23] ) Q[23] = Q[k];
		public static void GetCPUTimeAllotedForN(int []Q)
				Q[24] = Q[27] * Q[24];
so_calAsked:
so_calAuthor Commented:
Java columns
mccarlIT Business Systems Analyst / Software DeveloperCommented:
Once you have populated the arrays, you just need to print the value for each array in the one statement, ie. something like this...
System.out.format("%20s%20s%20s%n", "Array N", "Array M", "Array P");
    System.out.format("%20d%20d%20d%n", N[k], M[k], P[k]);
Hmm. Okay. It's telling me:
"Error: Main method not found in class JRoundRobin, please define the main method as:
   public static void main(String[] args)
or a JavaFX application class must extend javafx.application.Application"
Cloud Class® Course: MCSA MCSE Windows Server 2012
This course teaches how to install and configure Windows Server 2012 R2.  It is the first step on your path to becoming a Microsoft Certified Solutions Expert (MCSE).
You've messed up something else in your code then. Post the (new) full code.
    public static void main(String[] Me, Object arg1){
 		int k;
 		boolean IsItFilled;
				N[k] = 0;
				M[k] = 0;
				P[k] = 0;
		IsItFilled = true;
		while (IsItFilled)
						if (N[19] != 0 )
							IsItFilled = false;
			GetSumForN(N);
			GetAverageForN(N);
			GetBiggestForN(N);
			GetSmallestForN(N);
       StartTime    = 0;
       EndTime      = 0;
       IndexFilled  = 0;
		   if ( Q[k] == 0 )
				IndexFilled = k;
				k = 21;
	   k = IndexFilled;
	   while ( k < 20 )
	   			Q[k] = Holder;
	   			k++;
					k = 21;
	   Q[27] +=1;
			int k;
					Q[20] += Q[k];
			Q[21] = Q[20]/20;
				int k;
				int k;
Getting some progress...
Need the other arrays to populate as well as get the averages, etc.
Ok
I still need some help in getting this Java program to work.
Yeah ok, but you will need to tell us what problems you are having so that we can try to help!
I'm unable to get Array M and Array P to populate. Do I just copy the code I have for Array N and paste it somewhere? If so, where?
What would be the code to get the Total, Average, etc? Is is something like System.out.format ("\n total ,n[20] ?
Pretty lost here.
Getting a lot of errors:
F:\JRoundRobin.java:74: error: illegal start of expression
F:\JRoundRobin.java:74: error: ';' expected
F:\JRoundRobin.java:74: error: '.class' expected
F:\JRoundRobin.java:149: error: illegal start of expression
F:\JRoundRobin.java:149: error: ';' expected
F:\JRoundRobin.java:149: error: '.class' expected
F:\JRoundRobin.java:184: error: illegal start of expression
F:\JRoundRobin.java:184: error: ';' expected
F:\JRoundRobin.java:184: error: '.class' expected
F:\JRoundRobin.java:192: error: illegal start of expression
F:\JRoundRobin.java:192: error: ';' expected
F:\JRoundRobin.java:192: error: '.class' expected
F:\JRoundRobin.java:196: error: illegal start of expression
F:\JRoundRobin.java:196: error: ';' expected
F:\JRoundRobin.java:196: error: '.class' expected
F:\JRoundRobin.java:204: error: illegal start of expression
F:\JRoundRobin.java:204: error: ';' expected
F:\JRoundRobin.java:204: error: '.class' expected
F:\JRoundRobin.java:213: error: illegal start of expression
F:\JRoundRobin.java:213: error: ';' expected
F:\JRoundRobin.java:213: error: '.class' expected
F:\JRoundRobin.java:217: error: illegal start of expression
            public static void Heading()
F:\JRoundRobin.java:217: error: ';' expected
F:\JRoundRobin.java:222: error: reached end of file while parsing
40 errors
Tool completed with exit code 1
dpearsonCommented:
When you get an error about illegal *start* of expression:
it usually means you made a mistake just before it.
E.g. The code you posted:
is missing a close " and )
System.out.format ("\n total" ,n[20]) ;
So have a look at the code just before the explosion of errors.
Doug
First, can you clarify a couple of points for us just to set the context of your question...
Is this a homework/academic related question?
And, is the code that you have posted someone else's? And you are trying to either understand it, extend it or complete it?
Firstly, if you look at the methods towards the bottom of the code, the ones the "Populate" or "GetXXXX", they all take an array as an argument so they don't necessarily have to operate on the N array. So I would take the N out of the names of those methods, eg.
PopulateTheNArray    would become      PopulateTheArray
GetSmallestForN         would become      GetSmallest    or    GetSmallestForArray
etc...
Now to answer your specific question, I can't really help too much just at the moment because from what you have told us so far, I have no idea what each of the N, M and P arrays need to be populated with, I have no idea what they mean. You would need to describe in more detail what you are trying to do.
Thank you for that.
Yes, this is a homework/academic question.
Most of is is the code the instructor has provided. Yes, I am trying to understand it, and extend it to look like the finished product. The problem is that I don't know how to get to the finished product.
Basically I have part of the code without any errors (RoundRobin.java), but more code needs to be added to make it more functional. So, Array M, and Array P are to generate random numbers, which they are currently not. The Arrays are just names.
Notice Array N = two digits, Array M = 3 digits, Array P = 4 digits. I also need the total, average, biggest, smallest, etc
The code from Array N could be reused to make Array M and P, but changing the M instead of N, and 1000 instead of 100, or something like that. Also the numbers are to be right-aligned.
Final Product should look like
Ok at this point, all I can say is that we are a long way off track from the original question and we would still have a very long way to go before you would be happy.
SO, all I can suggest at the moment is that if you are happy with the feedback provided in response to your initial question only, then I would ask you to resolve this question as you see fit. And then you can open a new question to get more help for the current issues. However I would suggest that you still need to provide much more information about what you are trying to do. Your statements above are still too vague to grasp what you want. Your comment of "or something like that" is never going to be precise enough to communicate too us what you need the code to do.
Thank you, this has been helpful.
Thank you, you have been very helpful.
You're welcome!
Java
