Help with copying partial data from Data Element A to Dta Element B using VB.NET
I have an xml file as shown if Part A, how do I obtain xml file in Part B, for example I want to copy all text after 16 characters in <NSC> to <RN>, if NSC contains xxxx-xx-xxx-xxxx(1) or NSC contains xxxx-xx-xxx-xxxx(1, 2 ) I want to copy (1) or (1,2) to <RN>. The xml file contains additional data elements not shown in my example.
Part A
<Root>
<Table>
<ID>1</ID>
<NSC>xxxx-xx-xxx-xxxx(1)</NSC>
<RN><RN>
</Table>
<Table>
<ID>2</ID>
<NSC>xxxx-xx-xxx-xxxx(1,2)</NSC>
<RN><RN>
</Table>
<Table>
<ID>3</ID>
<NSC>xxxx-xx-xxx-xxxx(1,2.3)</NSC>
<RN><RN>
</Table>
</Root>
Part B:
<Root>
<Table>
<ID>1</ID>
<NSC>xxxx-xx-xxx-xxxx</NSC>
<RN>(1)</RN>
</Table>
<Table>
<ID>2</ID>
<RN>(1,2)</RN>
</Table>
<Table>
<ID>3</ID>
<RN>(1,2.3)</RN>
</Table>
</Root>
Victor
vcharlesAsked:
Robert SchuttSoftware EngineerCommented:
How about this:
    Private Sub DoTransform()
        Const C_CUTOFF_LENGTH As Integer = 16
        Dim objFileA As New XmlDocument
        objFileA.Load("FileA.xml")
        For Each objTable As XmlElement In objFileA.DocumentElement.SelectNodes("Table")
            Dim objNodeNSC As XmlElement
            objNodeNSC = objTable.SelectSingleNode("NSC")
            If objNodeNSC IsNot Nothing AndAlso objNodeNSC.InnerText.Length > C_CUTOFF_LENGTH Then
                Dim objNodeRN As XmlElement
                objNodeRN = objTable.SelectSingleNode("RN")
                If objNodeRN Is Nothing Then
                    objNodeRN = objTable.AppendChild(objFileA.CreateElement("RN"))
                End If
                objNodeRN.InnerText = objNodeNSC.InnerText.Substring(C_CUTOFF_LENGTH)
                objNodeNSC.InnerText = objNodeNSC.InnerText.Substring(0, C_CUTOFF_LENGTH)
            End If
        Next
        objFileA.Save("FileB.xml")
    End Sub
Fernando SotoRetiredCommented:
Hi Victor;
The following code snippet using Linq to XML should give you what you are looking for. I am assuming you what the resulting XML file to be the same as the original with the changes stated.
Dim partA As XDocument = XDocument.Load("C:\Working Directory\partA.xml")
Dim nodes = (From node In partA.Descendants("Table")
             Where node.Element("NSC").Value.Length > 16
             Select
                NSC = node.Element("NSC"),
                RNValue = node.Element("NSC").Value.Substring(16),
                RN = node.Element("RN")).ToList()
For Each node In nodes
    node.NSC.Value = node.NSC.Value.Substring(0, 15)
    node.RN.Value = node.RNValue
Next
partA.Save("C\Working Directory\partB.xml")
vcharlesAuthor Commented:
Hello Fernando, Robert;
Thank you for the solutions.
Victor
.NET Programming
