HardwareDude
Electrical engineering: low volt solar pannel/battery/air pump question.
Hello Experts.
I have a 15 Watt, 12V solar panel : ( http://sunelec.com/solar-panels/12v-solar-panels/sun-15-watt-solar-panel-12v.html ), currently powering up a 12v, .3A air pump ( http://www.amazon.com/gp/product/B000EYWNVQ ) to aireate a fish pond. I'd like to run the air pump 24/7 by introducing a 12V 10AH battery (http://www.amazon.com/gp/product/B00B8U3GOI ) and a charger controller (http://www.amazon.com/gp/product/B004Q820UK ) to this system. How do I wire them together? I’d like the system to run unattended. If I purchased the wrong controller for this application, can you recommend a different one?
Did you solve your problem? Is it working?
