Victor Charles
Help with removing Data elemnts not included in string variable using VB.NET
How do you modify the code to remove all Data elements in an xml file not found in a string variable S = "Effect, NSC, NSN, AGD" using VB.NET?
Victor
Victor
Hi Fernando,
Thanks for the code, unfortunately it's working the opposite way, I would like to delete all data elements not included in the string ({"Effect", "NSC", "NSN", "AGD" }). Instead the code deletes the data elements in the string.
Victor
Victor
Thanks, I will try it when i get home. Also how do you achieve the same if the data elements are in an xml file?
I can open if new case if you prefer.
Thanks.
Thanks.
That was in an XML file.
I meant, using values from file2.xml
<Table>
<Effect>
<NSC>
<NSN>
<AGD>
<Table>
I will try the codr and get back to you.
Victor
<Table>
<Effect>
<NSC>
<NSN>
<AGD>
<Table>
Victor
Thank You.
Hi Victor, can you please open a new question for your last post. Thanks
This should work.
