rgb192
fix iphone 5s parts
what are all the tools required to
fix screen on iphone 5s
I saw in one video a type of plastic tongs holder
what type of screw drivers
and other parts
and other parts
The best approach is to get a kit that includes the screen. You need a pentalobe screwdriver to take the iPhone apart. It will be included and is good for one use. The screws are included also. Any sealer will be included. So get a screen replacement kit and you should be good to go.
If you look on Amazon for screen replacement kits you'll see the typical set of tools .. small philips 000 (cross-head) and small p2 pentalobe screwdriver - a couple of plastic tools to pry and separate the screen and a tweezers (unless you have delicate fingers).
A quick look in iFixit.com will find the step-by-step guide to replacing the front glass and most iPhone 5s replacement kits on Amazon and elsewhere will include these tools and plastic bits
iFixit is going to be the best bet for this. They have in-depth guides, tricks, tools, and parts that you'll need to replace this yourself. I've helped a friend replace the screen on their iPhone 4 before using their guides/parts and it was super easy.
https://www.ifixit.com/Device/iPhone_5s
https://www.ifixit.com/Guide/iPhone+5s+Front+Panel+Replacement/22096
everything written
thanks
thanks
