Entry not found in index or view's index not built
Strange error now getting when I open a new form request.  I made no changes to the form, but nosw I'm getting this error.  billable_lookup: entry not found in index or view's index not built.
This billable_lookup is a hidden field on the form that perms this dblookup
temp := @DbLookup("":"NO CACHE"; ""; "GThidden";OOusername; "Billable");
@If(@IsError(temp) & OOusername != "";
@Prompt([Ok];"Automation Error";"Billable hours look up error.");temp)
the gthidden is a view to a different memberprofile form that someones doc would have a field called Billable checked as yes or no.
Always worked, but now when I open a new request I'm getting that popup error box.
Ideas ??
Thank You !
Paul
LVL 4
pratiganAsked:
Steve KnightIT ConsultancyCommented:
Ok so there is something in the view GTHidden that is wrong, maybe replication conflict documents, someone has fiddled with the view and broken it or maybe the username doesn't match any more.
For starters I would:
Open the GTHidden view to have a look - if it is actually a hidden one with ( ) around name and not shown in View menu then hold down Control Shift while you select View menu and Goto and can select it from there.
Look at the form of hte document you are creating.  What is the value of the OOUsername field - is that exactly the same as the entry in that view, e.g. unhide the field or put in @prompt([OK];OOUsername); to appear when the form opens temporarily.
Could be just going into the view and pressing Shift-F9 to rebuild the view will help, or press Control Shift F9 and rebuild all views in the database.
Steve
pratiganAuthor Commented:
You had me looking in the right directions.  Once I went in and looked closer at the billable_lookup field, I noticed the:
logic was in the default value section of the field instead of in the Input Translation section.  This is why the DBLookup was trying to execute when I would click on create new request and the OOusername wasn't even populated yet.  I moved the lookup to the Input Translation and no more error.
Thank You !!
Great redirect.
Thank You !!  Very much appreciated.
Glad you sorted it!
Steve
Lotus IBM
