Power Shell command for Users in AD
I need to generate report  in power shell for all users in OU with password expiration date and latest date password change .
Policy to change password is 45 days
I have OU for all regions as
OU = region1 then
OU =Country x
then Users , workstations and servers
I know Get-ADUser  is to get al require information but I need to add parameters as filter to get require information in report .
can you help
salmaaloufAsked:
Jeremy WeisingerSenior Network Consultant / EngineerCommented:
Are you wanting to know how to export the gathered information into a report or how to limit the Get-ADUser cmdlet to just the OUs you want?
If you're wanting to limit it, you can specify the -searchbase as the OU you want to be the root of your search.
salmaaloufAuthor Commented:
I want to limit the Get-ADUser cmdlet to just the OUs I want , can you send me the full command
Sure, the command is:
Get-ADUser -Filter * -Searchbase "<dn of OU>"
SD-WAN: Making It Work for You
As bandwidth requirements and Internet costs grow, businesses naturally want to manage budgets by reducing reliance on their most expensive connection types. Learn more about how to make SD-WAN work for your business in our on-demand webinar!
IF I want to add two OU  it should be like that  :
Get-ADUser -Filter * -Searchbase "<OU = region1 ,OU =Country x>"
and what about password expiration date and latest date password change . what parameters should I add .
So let's say you have the following OUs you want to get the info from:
- domain.com\APAC\JP
- domain.com\EMEA\DE
You would want the following:
$ADUsers = Get-ADUser -Filter * -SearchBase "OU=JP,OU=APAC,DC=domain,DC=com" -Properties msDS-UserPasswordExpiryTimeComputed,PasswordLastSet
$ADUsers += Get-ADUser -Filter * -SearchBase "OU=DE,OU=EMEA,DC=domain,DC=com" -Properties msDS-UserPasswordExpiryTimeComputed,PasswordLastSet
$ADUsers | select name.PasswordLastSet,@{name='PasswordExpires';Expression={[datetime]::FromFileTime($_.'msDS-UserPasswordExpiryTimeComputed')}}
I run  script but output of name and password last set is empty , can you check please
Did take a look for screen shot I attached
Don't see the screenshot but I do see the issue. I typed a period (.) instead of a comma (,) in the select statement. Here's the corrected script:
$ADUsers | select name,PasswordLastSet,@{name='PasswordExpires';Expression={[datetime]::FromFileTime($_.'msDS-UserPasswordExpiryTimeComputed')}}
That work perfectly  , is there is a way to export to excel file
Sure, just pipe it to Export-CSV:
[code]
$ADUsers | select name,PasswordLastSet,@{name='PasswordExpires';Expression={[datetime]::FromFileTime($_.'msDS-UserPasswordExpiryTimeComputed')}} | Export-CSV C:\output.csv [code]
Very good support and response time .
Powershell
