Problem running command from C drive using CMD
Good evening,
We are installing some libraries on our server. I am not sure if this is a permissions problem. I am running this from the CMD as Administrator.
We go to:   cd C:\Program Files (x86)\Microsoft SDKs\Windows\v7.0A\bin
To run the following command:
ildasm M:\Web\QFEBridgeTest\QFEBridgeTest\bin\Release\QFEBridgeTest.dll /outM:\Web\QFEBridgeTest\QFEBridgeTest\bin\Release\QFEBridgeTest.il
I am running the command from drive C, the files are on drive M and it is giving me an error saying it cannot access the files.
If the files were on C it would be fine, but I am running my websites off M. So that is were the files are, the command works fine (We tested various times in different computers, but all use C for the web).
I am trying to figure out how to access the files on M running this command from a C location.
Is this permissions or do you have any advice on how we should run the command?
(View attached screenshot)
LVL 1
AleksAsked:
Bill PrewIT / Software Engineering ConsultantCommented:
I think you have a typo with the /out option, I think it needs an "=" after it, as in:
ildasm M:\Web\QFEBridgeTest\QFEBridgeTest\bin\Release\QFEBridgeTest.dll /out=M:\Web\QFEBridgeTest\QFEBridgeTest\bin\Release\QFEBridgeTest.il
~bp
AleksAuthor Commented:
Thanks, that fixed that one. The last two instructions may have an error as well.  Your input will be greatly appreciated:
regasm M:\Web\QFEBridgeTest\QFEBridgeTest\bin\Release\QFEBridgeTest.dll /codebase/tlb:M:\Web\QFEBridgeTest\QFEBridgeTest\bin\Release\QFEBridgeTest.tlb
AND
regasm M:\Web\QFEBridgeTest\QFEBridgeTest\bin\Release\QuikFormsEngine.dll /codebase/tlb:M:\Web\QFEBridgeTest\QFEBridgeTest\bin\Release\QuikFormsEngine.tlb
I also tried:
regasm M:\Web\QFEBridgeTest\QFEBridgeTest\bin\Release\QFEBridgeTest.dll/codebase/tlb:M:\Web\QFEBridgeTest\QFEBridgeTest\bin\Release\QFEBridgeTest.tlb
but got:  The given path is not supported.
Making Bulk Changes to Active Directory
Watch this video to see how easy it is to make mass changes to Active Directory from an external text file without using complicated scripts.
You need a space after the /codebase option, like:
regasm M:\Web\QFEBridgeTest\QFEBridgeTest\bin\Release\QFEBridgeTest.dll /codebase /tlb:M:\Web\QFEBridgeTest\QFEBridgeTest\bin\Release\QFEBridgeTest.tlb
regasm M:\Web\QFEBridgeTest\QFEBridgeTest\bin\Release\QuikFormsEngine.dll /codebase /tlb:M:\Web\QFEBridgeTest\QFEBridgeTest\bin\Release\QuikFormsEngine.tlb
~bp
Ok .. I am running everything again from scratch .. Ill update you in 5 min.
Almost there. I ran all my commands, but those last two you provided me with are giving an error.
Attached are the two errors I get when I run the commands.
First one is: Strong name validation failed.
Once I get this two commands to run am in the clear  :)
David Johnson, CD, MVPOwnerCommented:
regasm C:\Web\QFEBridgeTest\QFEBridgeTest\bin\Release\QuikFormsEngine.dll /codebase /tlb:M:\Web\QFEBridgeTest\QFEBridgeTest\bin\Release\QuikFormsEngine.tlb
David: The files are on M, not C.  If I enter "C" It says the .dll cannot be found.
This are the two commands that are giving me that error:
I think the second command may have worked, just with a warning.  The first can't find your QFEBridgeTest module, but I'm not sure why that is.
~bp
the path is correct though. I made sure. I want to concentrate on the first one first.
I located the file, it is at:
This is the command I am running for it:
This is the error:  Strong Name validation failed
This file is also in the same folder:  QFEBridgeTest.tlb
So the paths are correct.
Thanks for the help !
Windows Server 2008
