SharePoint 2013, Web Parts and JavaScript Includes
I have a SharePoint 2010 Solution which I need to port to SharePoint 2013.  It has a page with a list on it and a lot of related JavaScript which handle some rendering of the page as well as a jQuery Tree view for navigation.   The original solution used a customized master page which referenced jQuery.js,  SPServices.js, sp.js, sp.core.js. sp.runtime.debug.js and several helper modules specific to the solution.
My goal is to not use  a customized master page for the port and to put these "master page" includes into a script web part.  Additionally I have a scripting web part to load the jquery tree view html file, a filter web part which allows the main list view to get filtered and another scripting web part which has a set of JavaScript modules which drive the page.
Much of the port seems to be shaping up.  But there are some issues which I think are related to when the various modules load which having them housed in the master page handled.
In particular,  I thought that having these lines in my top most web part would ensure that they would be available for all subsequent web parts:
<SharePoint:ScriptLink ID="ScriptLink21" Name="sp.js" runat="server" OnDemand="false"  LoadAfterUI="true" Localizable="false" />
<SharePoint:ScriptLink ID="ScriptLink22" Name="sp.Core.js" runat="server" OnDemand="false"  LoadAfterUI="true" Localizable="false" />
<SharePoint:ScriptLink ID="ScriptLink23" Name="sp.RunTime.Debug.js" runat="server" OnDemand="false"  LoadAfterUI="true" Localizable="false" />  <--Does ScriptLink tag work in web part or only on master pages?
Apparently I am missing something here and I am not getting these modules loaded first.
Any wisdom in general and specifically to what I am trying to accomplish would be greatly appreciated.
Also,  to reference the above modules, do I need to prefix their names with "_layouts/" ,  "_layouts/15/" or not?
LVL 1
Howard BashSenior Software EngineerAsked:
bissellGRCommented:
Without seeing any of your code, and guessing on what could be happening (as I just went through this last week), you may need to have at the start of your WebPart the following:
     ExecuteOrDelayUntilScriptLoaded(functionName,"sp.js");
This will allow the function to run once sp.js is installed. See if that helps.
Microsoft SharePoint
