VBA Syntax MS Access 2013: (Correct datatype and syntax for casting/conversion) for use in WHERE criteria statement in SELECT FROM WHERE string SQL query
Currently having an issue while using string variable TSx=arrayREP(0, i) for WHERE criteria statement in SELECT FROM WHERE string SQL query.
 TSx = ("criteriax") because Dim variable As String and I need [(criteriax)-returned value from array not wrapped in " "] for query to act properly.
Dim TSx As String
Dim QRYx As String
TSx = arrayREP(0, i)
QRYx = "SELECT tbl.field1, tbl.field2, tbl.field3, tbl.field4, tbl.field5, tbl.field6, tbl.field7,FROM tbl WHERE tbl.field1=TSx"
Any suggestions?
Box asking for parameters for TSx appears after running. If I enter the value for TSx without the " " wrapped around it from using string variable everything else works perfectly.
I've been self-teaching over the past two days and so far this is only trouble I'm having, probably because its within a For Next Loop. Hopefully just a minor fix/conversion.
Thanks!
Cole
yop6Asked:
Mike EghtebasDatabase and Application DeveloperCommented:
WHERE tbl.field1=" & chr(34) & TSx & chr(34)
If TSx does not contain any single quotes, you can use:
WHERE tbl.field1='" TSx & "'"
here we have = ' " TSx & " ' " in expanded for for you to see single quotes and double quotes.
But, if you expect to have single quotes like TSx "O'Donald" then use of chr(34) is required.
Rey Obrero (Capricorn1)Commented:
where is you code for the loop?
why not just pass the element of the array to the query?
what DATA type is the field you are filtering, Number or Text?
how about making Tsx as variant
Dim TSx
Dim QRYx As String
what value do you get for TSx?
yop6Author Commented:
@Mike
I may have been unclear. TSx currently returns "75-X-4553" in first loop from 0 to 99 i=0 because its a string. I know i can't use it for my Criteria because the return I'm looking for in tbl.field1 is 75-X-4553.
@Ray
Dim VBA_16 As DAO.Database
Set VBA_16 = CurrentDb
Dim arrayREP() As Variant
Dim rstREP As DAO.Recordset
Set rstREP = VBA_16.OpenRecordset("SELECT TSx, QRYx, PATHx FROM tblREP", dbOpenDynaset)
With rstREP
    .MoveLast
    .MoveFirst
    arrayREP = rstREP.GetRows(.RecordCount)
End With
rstREP.Close
    Set rstREP = Nothing
'Looping through rstGWA using arrayREP for variables
Dim rstGWA As DAO.Recordset
Set rstGWA = VBA_16.OpenRecordset("Qry_GWA")
For i = 0 To 99
Dim TSx As String
Dim PATHx As String
Dim QRYx As String
Dim qdfQRY As QueryDef
i = 0
PATHx = arrayREP(2, i)
QRYx = "SELECT Qry_GWA.[Treasury Symbol], Qry_GWA.Authority, Qry_GWA.Transfers, Qry_GWA.GrossDisb, Qry_GWA.OffsetCollect, Qry_GWA.EndBal, Qry_GWA.BegBal FROM Qry_GWA WHERE Qry_GWA.[Treasury Symbol] =TSx"
Set qdfQRY = VBA_16.CreateQueryDef("", _
QRYx)
DoCmd.TransferSpreadsheet acExport, 10, "qdfQRY", PATHx, False, "DataGWA"
Next i
rstGWA.Close
    Set rstGWA = Nothing
Any suggestions on how to clean this up or improve performance would be appreciated as well. I'm pretty green.
Thanks!
< TSx currently returns "75-X-4553" in first loop from 0 to 99 i=0 because its a string. I know i can't use it for my Criteria because the return I'm looking for in tbl.field1 is 75-X-4553. >
copy and paste the statement below
QRYx = "SELECT Qry_GWA.[Treasury Symbol], Qry_GWA.Authority, Qry_GWA.Transfers, Qry_GWA.GrossDisb, Qry_GWA.OffsetCollect, Qry_GWA.EndBal, Qry_GWA.BegBal FROM Qry_GWA WHERE Qry_GWA.[Treasury Symbol] ='" & TSx &"'"
post back the result
TSx Parameter Box.
WHERE Qry_GWA.[Treasury Symbol] ='75-X-4553'
Double quotations were replaced with single quotations. Any way to remove single quotations?
@yop6,
<Double quotations were replaced with single quotations. Any way to remove single quotations? >
the single quotations MUST remain to make your query work.
your problem lies in the succeding lines
 QRYx)
you can not pass a query def to an export command, you have to pass the a SAVED query name.
to do this, create a query with this statement, save the query as myQuery
open the query and see the result..
post back the result... if the result is good we will proceed with your looping codes with altering the query def statement
could you give me syntax for saving the query as my query
place this code in a regular module and run
Sub TestQdf()
Dim QRYx As String
Dim qdfQRY As DAO.QueryDef
Set qdfQRY = VBA_16.CreateQueryDef("myQuery", QRYx)
 DoCmd.openquery "myQuery"
 end sub
OK, that did exactly what I needed it to do. Thanks! Now after my DoCmd. for exporting it seems like I will have to either delete the query or rename it temporarily as I'm looping.
you can delete the query then recreate
place this inside your loop
if dcount("*","msysobjects","[name]='myQuery'") > 0 then
     docmd.delateobject acquery, "myQuery"
end if
Extremely helpful!
another way is to just change t the SQL statement of the the saved query..
if you want to tackle this.. post another q.
Microsoft Access
