How to split a multipart string into two parts
I could do this with basic string manipulation but I was hoping that there was a cleaner method, perhaps using regular expressions. What I want to do is separate a multipart string into two basic parts. Assuming I have the following string:
"First.Second.Third.Fourth"
The result I would want is:
"First.Second.Third"
"Fourth"
Is there a nice clean Regex or Linq way of doing this or am I just going to have to use the regular string.Split() method and manually reassemble what I want?
LVL 21
Russ SuterAsked:
käµfm³d 👽Commented:
What are the rules for splitting?
Russ SuterAuthor Commented:
Whatever they need to be to accomplish the goal.
käµfm³d 👽Commented:
Well I was asking how one (or I) would know where the split should occur. Based on what you shown above you could use:
string[] parts = Regex.Split(source, @"(?<=\w+(?:\.\w+){2})\.(?=.*)");
That only works for exactly for what you've posted above. If your rules are different, then the pattern would need to be tweaked.
Neil RussellTechnical Development LeadCommented:
A random example like that will need a clearly defined set of rules.
Are you saying you always want from the last Period onwards to be a separate string?
I always want exactly two strings. The first will be everything to the left of the rightmost "." character. The second will be everything to the right of the rightmost "." character.
käµfm³d 👽Commented:
Then you could adjust the pattern to:
string[] parts = Regex.Split(source, @"\.(?=\w+$)");
Gustav BrockCIOCommented:
You can use Split and Join:
string allParts = "First.Second.Third.Fourth";
char separator = '.';
string[] parts = allParts.Split(separator);
int lastIndex = parts.Length - 1;
string firstPart = string.Join(separator.ToString(), parts, 0, lastIndex);
string lastPart = parts[lastIndex];
Will return:
    First.Second.Third
    Fourth
/gustav
louisfrCommented:
\w works only for alphanumeric characters. If there is a space or whatever after the last period, you won't get any match. Use [^.] instead:
string[] parts = Regex.Split(source, @"\.(?=[^.]+$)");
That last Regex pattern did the trick. Although I might replace the "+" with a "*" since I would want to return an empty string as the 2nd part if the string I'm testing ended with a "." character.
käµfm³d 👽Commented:
This is why we ask for specific rules and example when regexes are requested. As you can see above, some of us are better at guessing games than others.
C#
