Got Stuck at a place in my project , need help to proceed
Basically I have  a section of complain registration , here user registers a complain and a mail is send to the admin , then admin performs some action and mail is received by the user , If a user is satisfied , the complain is closed by the admin else the user needs to update the complain, Now I want to have the complete history of how many times user updates and the action performed the admin.....So how can i store the complete history in my database and display it in the form of report...I have made two tables for it....
1) User_Complain
CREATE TABLE [dbo].[User_Complain] (
    [Complain_Id]   INT         IDENTITY (1, 1) NOT NULL,
    [Flat]          INT         NOT NULL,
    [Complain_Name] NCHAR (70)  NOT NULL,
    [Description]   NCHAR (100) NOT NULL,
    [Status]        NCHAR (50)  NOT NULL,
    [Date]          DATE        NOT NULL,
    [Time]          TIME (7)    NOT NULL
2)Admin_Action
CREATE TABLE [dbo].[Admin_Action] (
    [Complain_Id]      INT         NOT NULL,
    [Action_Performed] NCHAR (500) NOT NULL,
    [Status]           NCHAR (25)  NOT NULL,
Sukesh ShuklaAsked:
TEKDesignCEO/Consultant/OwnerCommented:
Well to help we will need an explanation of what you intend to use each variable in the tables for. I would also suggest that this could be done with one table tracking the complaint and its status itself and another table tracking the conversation between the users and admins and actions taken by the admins...it might even be possible to do everything with one single table...
Sukesh ShuklaAuthor Commented:
Hi
See, there is a unique complain id , them Flat is the Flat number then Complain_Name is for ex water related problem, Description gives the detailed explaination and action_Performed is the action performed by the admin and finally is the date and time ......
ok, I understand better now. this is for complaints to a building supervisor so they problems can be addresses and fixed. I mentioned you should restructure your tables and rethink your programming process logic. So how and where are you stuck?
Cloud Class® Course: SQL Server Core 2016
This course will introduce you to SQL Server Core 2016, as well as teach you about SSMS, data tools, installation, server configuration, using Management Studio, and writing and executing queries.
I'm basically struck at a point , as to how to store the complete conversation and how to display it in the form of reports
Ok, start by restructuring your tables to hold the information you need specific to each part of your problem. Store the complaint information in one table and the conversation about the complaint in the other. Their should be an ID reference from the conversation table to the complaint table. Then to run the report you simply pull the complaint you want to run a history of from the complain table and then once you know the complaint ID use it to retrieve only the conversation records that reference that ID.
So can you please tell me how my complain table and conversation table should be designed ie what all columns should I use in them according to you ........So that data storage gets easier and not at all confusing.....
Now I'm not going to do all the work for you but I will tell you this. Keep you complaint table as is...just rename it from "user_complaint" to "complaints". The second table rename it "conversations" and eliminate the fields that are dublicates from the complaint table keeping only the complaint_id which references back to the complaint table and add fields for id (unique id per conversation record), users name, user type, comment, and action taken. reformat the tables and repost them and I'll let you know if you are close. then all you need to do is write the code to access the information in the tables to list the conversation history per complaint.
ASP.NET
