Using Case to apply a WHERE Clause - Need help with sytax
Hi all,
I need some help with my syntax for the " Where " part of the following SPROC. I am passing it a INT value and want to set the " where " clause depending on what value I sent it. What is the correct syntax. I have tried the below but it does not work.
Many thanks in advance
BEGIN
SELECT st.Student_ID
  , st.Student_Name
  , st.Student_SurNames
From tbl_Students st
CASE @StuType
      WHEN 0 THEN
      WHERE IsNull(Enr_Activate_Done,1) = 1
END
CASE @StuType
      WHEN 1 THEN
    AND st.Student_IconImage = 1
END
CASE @StuType
      WHEN 2 THEN
    AND st.Student_IconImage = 2
END
ORDER by st.Student_GivenID
END
LVL 5
Abiel de GrootDeveloperAsked:
Vitor MontalvãoMSSQL Senior EngineerCommented:
Why not this?
   , st.Student_Name
FROM tbl_Students st
    AND (@StuType = 0 OR st.Student_IconImage = @StuType)
Abiel de GrootDeveloperAuthor Commented:
I really need to modify the WHERE clause depending on the Variable value. I see what you are saying, but is there a way to modify the whole where clause? The above is more of an example, I may need to further vary the Where clause depending on the Int passed
Many thanks Vitor ;-)
A CASE in the WHERE clause most of the times can be transformed into logic operators so it's better to show us the real case so we can help you better.
Otherwise you'll need to work with SQL dynamic (built the SELECT command and execute it with EXEC() function).
IT Pros Agree: AI and Machine Learning Key
We’d all like to think our company’s data is well protected, but when you ask IT professionals they admit the data probably is not as safe as it could be.
Ok, I got so far ...
AND
  CASE @StuType
  WHEN 0 THEN st.Student_ID > 0 ELSE NULL
  END
, CASE @StuType
  WHEN 1 THEN st.Student_IconImage = 1 ELSE NULL
  END
, CASE @StuType
  WHEN 2 THEN st.Student_IconImage = 2 ELSE NULL
  END
, CASE @StuType
  WHEN 3 THEN st.Student_IconImage = 3 ELSE NULL
  END
END
Well, I still keep my above solution to your question but anyway:
  WHERE ((@StuType = 0 AND st.Student_ID > 0)
   OR st.Student_IconImage = CASE @StuType
           WHEN 1 THEN 1
           WHEN 2 THEN 2
           WHEN 3 THEN 3)
As you can see isn't so good to read.
Sorry, you were right!
Many thanks
A
Query Syntax
