Start Free TrialLog in
Avatar of Keith McElroy
Keith McElroy
vb script run on 64 bit machine but use 32 bit so create mdb will work
Is there a way to run a vbs script from within a file such as myscript.vbs that would use the 32 bit script tool so that I do not need to send my user to the command prompt?
Screenshot:
http://www.screencast.com/t/56p1nA3XGdQr
Avatar of Mohammed Khawaja
Mohammed Khawaja
Flag of Canada image
Run your script as per below:
C:\windows\syswow64\wscript.exe myvbfile.vbs
Keith McElroy
Can I run this sequence from a .vbs file in some way?  Maybe declard the syswow64 so user does not need to go to the cmd prompt?
Avatar of Brendan M
Brendan M
Flag of Australia image
I think this is what I need, question though, why is this if statement here
If InStr(UCase(WScript.FullName), "SYSTEM32") > 0 Then
Is it assuming I put SYSTEM32 in the file name of the script?
May I remove this if statement?
Thanks for clarification.
I've requested that this question be closed as follows:
Accepted answer: 250 points for mnkhawaja's comment #a41402168
Assisted answer: 250 points for brendanmeyer's comment #a41402327
Assisted answer: 0 points for maxdbase's comment #a41402728
for the following reason:
Both answers equally great, I am going to use the short cut initially but later go with the in-scrpt method
