Swaminathan K
Difference between Oracle SQL and PLSQL -- reasons for preferring PLSQL when compared to SQL
Hi Team ,
I need reasons why PLSQL is used when compared to SQL . Any difference between them which makes us to use PLSQL instead of SQL.
Did you mean to post that in your other question?
There are examples in the documentation in the link I provided.
Sorry , this comment was for the previous post. Iam fine with the answer.
I Need an ral time example for both these triggers , I know why they are used for but not able to get an real time example . Even if the example is simple is fine , but need an good example. really appreciate , if you can provide one.
