Solved
My connection string does not connect when using username and password - SQL (Urgent)
Posted on 2016-08-02
7
Last Modified: 2016-08-06
Hi
We have just replaced the server at a client and I am now trying to get my software to connect to the SQL database.
The connection string for the previous server was:
data source=MYSERVERNAME;initial catalog=dbHCA;persist security info=True;user id=myuser;password=mypassword;MultipleActiveResultSets=True;
This returns an error login failed for user 'myuser'.
Server authentication is set to both SQL and Windows
My user uses SQL server authentication and is mapped to dbHCA as a db_owner.
The properties look exactly the same as the previous server.
Am I missing something?
I did not setup the SQL server and we are using SQL server 2016.
Please let me know if you require more information.
As a side note: I can connect using integrated security
Data Source=MYSERVERNAME;Initial Catalog=dbHCA;Integrated Security=True
Question by:elmbrook
  • 4
  • 2
7 Comments
LVL 56
Expert Comment
by:Ryan Chong
try to reset the password and use that new password in your connection string and try again?
Author Comment
by:elmbrook
Thank you for your reply.
That didn't work.
LVL 56
Assisted Solution
by:Ryan Chong
Ryan Chong earned 2000 total points
so, whats the error message you receiving now? are you connecting to the correct server?
What Kind of Coding Program is Right for You?
There are many ways to learn to code these days. From coding bootcamps like Flatiron School to online courses to totally free beginner resources. The best way to learn to code depends on many factors, but the most important one is you. See what course is best for you.
Author Comment
by:elmbrook
The error message is still the same.
I am connected to the new server.
I have written a quick programme to test connection strings to the server (see code below)
this connection string connects
which tells me that I can connect to the server using Windows Authentication
data source=MYSERVERNAME\;initial catalog=dbHCA;persist security info=True;user id=myuser;password=mynewpassword;MultipleActiveResultSets=True;
gives me the error which tells me SQL authentication is not working.
  private void button1_Click(object sender, EventArgs e)
            string txt = textBox1.Text.Trim();
            SqlConnection thisConnection = null;
            thisConnection = new SqlConnection(string.Format( txt));
            try
                thisConnection.Open();
                MessageBox.Show("Connected");
            catch (Exception ex)
                MessageBox.Show(ex.Message);
            textBox1.Text = "";
Accepted Solution
by:
elmbrook earned 0 total points
Oh man...I've been working on this for hours.
Finally, I followed Microsoft's Mantra - 'If all else fails...reboot' and guess what.
It works now...I am unsure why it never worked in the first place but thanks for your input.
LVL 27
Expert Comment
by:Zberteoc
I would remover "persist security info=True;" part.
Author Closing Comment
by:elmbrook
Reboot worked...Thanks for the help.
Build your data science skills into a career
Are you ready to take your data science career to the next step, or break into data science? With Springboard’s Data Science Career Track, you’ll master data science topics, have personalized career guidance, weekly calls with a data science expert, and a job guarantee.
Join & Write a Comment
When trying to connect from SSMS v17.x to a SQL Server Integration Services 2016 instance or previous version, you get the error “Connecting to the Integration Services service on the computer failed with the following error: 'The specified service …
In this article, we will show how to detach and attach a database and then show how to repair a corrupt database and attach it, If it has some errors. We will show how to detach and attach using SSMS or using T-SQL sentences.
Via a live example, show how to shrink a transaction log file down to a reasonable size.
Viewers will learn how to use the UPDATE and DELETE statements to change or remove existing data from their tables. Make a table: Update a specific column given a specific row using the UPDATE statement: Remove a set of values using the DELETE s…
601 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
