Using index/match with columns and rows - tables and how to automatically copy
I'm attaching a file. In the formulas sheet I have set up the first column (B - Carlow heading in table) to use index match to pull in the matching data from the Housing survey sheet. I get that I can copy/paste across and amend Carlow to matching counties. But if I wanted to just be able to copy this formula across...what tweak do I need to add to the formula to do this? EE_check_national_housing_developme.xlsx
