Why Is my IPhone 6 battery running out so quickly, and how do I fix It?
Why Is my iPhone 6 battery running out so quickly, & after I gave It a full over night charge? And how do I fix It?
Thanking you In advance for your prompt response.
L.S.
Leslie SpectorAsked:
JohnBusiness Consultant (Owner)Commented:
I have an iPhone SE (6s guts in a smaller form factor). Battery is good for all day.
The biggest factor in battery life for my old iPhone 4s was to set Fetch in all email to Manual. Only collect email when you want. By turning this off, the network card is not working overtime where it does not need to.
Go to Settings, General, and Reset and reset the Network Settings.
Now turn the phone OFF (Power right off), wait a minute and power on.
This should help your battery life.  You may also want to turn down the brightness but I do not.
I also charge fully at night, power off overnight every night, and start up the next day.
Jackie ManCommented:
How many battery cycle clocks is your Apple iPhone 6?
The battery is degraded over time. My wild guess is that you have used for your iPhone 6 over 18 months.
It is time to replace the battery or the iPhone if it does not hold the charge.
nobusCommented:
here is how to replace it :  https://www.youtube.com/watch?v=UgmtNJuqEHI
Download the app below to check the actual runtimes of your iPhone 6. The iPhone battery can do about 500 full charge cycles (0 – 100%).
Battery Life: check internal battery statistics
https://itunes.apple.com/hk/app/battery-life-check-internal/id1080930585?l=zh&mt=8
Reference:
https://searchman.com/ios/app/us/1080930585/en/robert-tkotzyk/battery-life-check-internal-battery-statistics/
http://www.appledystopia.com/how-to/calibrate-iphone-battery/
Kyle SantosCustomer RelationsCommented:
Go to Settings.
Battery
Observe battery usage over last 7 days.
What app are you using a lot?  Oftentimes I have noticed that the Home & Lock Screen uses a lot of battery power.  How can you stop this usage?
Whenever you're done using your iPhone, then you should get in the habit of 'locking' the screen by pressing the button on the top of the phone.  This will turn off the display until you need to get into the phone again.
AND
Go to Settings.
General.
Auto-Lock.
Set to 1 minute or less.
Let me know if you have any questions.
iOS
