how to write case statement or loop statement in simple sql query for same product with multiple sub products??
eg If I have product computer then sub products are like laptop,desktop,harddisk,ram etc
table is like productno | productsubno | productdesc|
                         1                         2                              laptop
                          1                          2                           desktop
                         1                         2                            harddisk                     like this...
and I want output like
product            productsubcode   desc1       desc2          desc3            etc...
1                                         2             laptop        desktop       hardisk
Please help in simple sql query...
newdeveloper india
newdeveloper india
Abhimanyu SuriSr Database EngineerCommented:
SELECT productno,
         productsubno,
         LISTAGG (productdesc, ',') WITHIN GROUP (ORDER BY productdesc)
    FROM TABLE_X
GROUP BY productno, productsubno
o/p :
1 2 laptop,desktop,hardisk
You can achieve output without commas by modifying
" LISTAGG (productdesc, ',') WITHIN GROUP (ORDER BY productdesc)"  TO
" LISTAGG (productdesc, '      ') WITHIN GROUP (ORDER BY productdesc)"
You can publish it as a csv by using
  SELECT productno||','||
         productsubno||','||
    FROM TABLE_X
1,2,laptop,desktop,hardisk
newdeveloper indiaAuthor Commented:
error found like this..
 FROM keyword not found where expected
PortletPaulCommented:
which query did you use? did you transcribe it accurately?
i.e. it is hard for use to know what that error relates to. Please copy/paste the EXACT query you used and the EXACT error message.
Free Tool: Path Explorer
