Need help on oracle data load tool -- Challenging Question
Hi Team,
I have an file the data in an input file called as emaidata.txt
"JobID"|"BatchID"|"SubID"|"EmailAddr"|"FirstName"|"LastName"|"pincode"|"SendDate"
"2796921"|"1442"|"151719024"|"RAJU@gmail.com"|""|""|""|"2016-07-31 02:40:37.697000000"
"2796926"|"487"|"75326115"|"CHANDRU@VINTEL.EDU"|""|""|""|"2016-07-31 01:39:52.070000000"
"2797764"|"1065"|"33696904"|"RAMCHAMDRA@GMAIL.COM"|""|""|""|"2016-07-29 20:34:14.113000000"
"2797764"|"5749"|"40004462"|"DSOUZA@VINTEL.edu"|""|""|""|"2016-07-30 14:52:42.443000000"
"2797764"|"13077"|"108620732"|"NAGAVENU@GMAIL.com"|""|""|""|"2016-07-31 15:19:48.123000000"
"2797764"|"13790"|"144806831"|"HAPPYTOHELP@outlook.com"|""|""|""|"2016-07-31 18:23:40.883000000"
"2797764"|"10633"|"42705052"|"venkatnarayan@vintel.edu"|""|""|""|"2016-07-31 06:14:53.760000000"
"2797764"|"13922"|"168459259"|"alxendar@outlook.com"|""|""|""|"2016-07-31 19:19:29.643000000"
I need to load this data into a table called as tmp_email. Below is the control file i have created , but it gives me an error.
Structure of Tmp_email
WORKID  NUMBER
 BatchID NUMBER
 SubID  NUMBER
 EmailAddr VARCHAR2(80)
 FirstName VARCHAR2(80)
 LastName VARCHAR2(80)
 pinCode NUMBER
 Senddate timestamp
load data
infile 'emaildata.txt'
TRUNCATE
into table TMP_email
fields terminated by '|'  OPTIONALLY ENCLOSED BY '"'
(WORKID  "RTRIM(LTRIM(:WORKID ,'\"'),'\"')",
 BatchID "RTRIM(LTRIM(:BatchID ,'"'),'"')",
 SubID  "RTRIM(LTRIM(:SubID ,'"'),'"')" ,
 EmailAddr "RTRIM(LTRIM(:EmailAddr ,'"'),'"')",
 FirstName "RTRIM(LTRIM(:FirstName ,'"'),'"')",
 LastName "RTRIM(LTRIM(:LastName ,'"'),'"')",
 pinCode "RTRIM(LTRIM(:PINCODE ,'"'),'"')",
 Senddate "RTRIM(LTRIM(:Senddate ,'"'),'"')" )
SQL*Loader: Release 11.2.0.1.0 - Production on Wed Oct 5 02:05:43 2016
Copyright (c) 1982, 2009, Oracle and/or its affiliates.  All rights reserved.
SQL*Loader-350: Syntax error at line 6.
Expecting "," or ")", found "),".
(JobID  "RTRIM(LTRIM(:JOBID ,'"'),'"')",
Also, I need to convert the string into timestamp.
Any help is really appreciated.
sam_2012Asked:
johnsoneSenior Oracle DBACommented:
I used the below and your sample data loaded just fine.
OPTIONS	(SKIP=1)
LOAD DATA
	INFILE *
	DISCARDMAX 9999
	APPEND INTO TABLE tmp_email
	fields terminated by "|" optionally enclosed by '"'
	trailing NULLCOLS
		WORKID,
		BATCHID,
		SUBID,
		EMAILADDR,
		FIRSTNAME,
		LASTNAME,
		PINCODE,
		SENDDATE TIMESTAMP 'YYYY-MM-DD HH24:MI:SS.FF9'
BEGINDATA
The optionally enclosed by will remove the double quotes.  Not sure why you are trying to do that with trim commands.  All you should need to do with the control file you have is to remove all the trims and add the format for the timestamp.
Pawan KumarDatabase ExpertCommented:
Try this on which the column you wanted to convert.
CASE WHEN TRY_PARSE(coltobeConverted AS DATETIME) IS NOT NULL THEN TO_TIMESTAMP (coltobeConverted, 'DD-Mon-RR HH24:MI:SS.FF') END
sam_2012Author Commented:
about the error Iam getting for rtrim and ltrim , also , I need to remove the " in the data while inserting into the database table.
Ok so do one thing , please post your query here..
This is the error Iam getting when I run sqlloader.
Can you provide us the entire query you have used in there?
In this question  i want to resolve the sqlldr issue
