Solved
Problem when configuring a power stack on a C3750X
Posted on 2016-10-26
6
Last Modified: 2016-10-27
I had a 4 members switch stack. I added a 5th, removed the 4th and renumbered the 5th to 4. "sh int status" shows Gi4/0/x Interfaces. So far so good. Now I created a power stack. I set power inline port priority. This doesn't work for switch 4. "sh power inline module 4" shows nothing. The same with module 5 brings up the port configuring for the old 5th stack member. What can cause this "split brain"?
Thanks a lot
Olaf
Question by:olaf_joerk
  • 4
6 Comments
LVL 20
Expert Comment
by:agonza07
Could be a software bug. Have you tried rebooting the entire stack?
Author Comment
by:olaf_joerk
Yes, I did. But I surely overlooked the link to the Switch model. I expected to get an output of "sh power inline ..." also for switches without PoE, not for the ports but the module itself. This is likely not the case apart from the headline. My current switch4 is without PoE. So there is no output or an error message respectively. My former switch5 was one with PoE. Somehow the stack is still remembering this Switch.
LVL 47
Accepted Solution
by:
Craig Beck earned 2000 total points
The 5th switch is still provisioned in config. Can you post the output from show run | i provision, please?
Get Certified for a Job in Cybersecurity
Want an exciting career in an emerging field? Earn your MS in Cybersecurity and get certified in ethical hacking or computer forensic investigation. WGU’s MSCSIA degree program was designed to meet the most recent U.S. Department of Homeland Security (DHS) and NSA guidelines.
Author Comment
by:olaf_joerk
You were right.
PHYSWU01#sh run | i provision
switch 1 provision ws-c3750x-24p
switch 2 provision ws-c3750x-24p
switch 3 provision ws-c3750x-24p
switch 4 provision ws-c3750x-48
switch 5 provision ws-c3750x-24p
"no switch 5 provision" will do the trick?
Author Comment
by:olaf_joerk
Yes it did. Thanks for your hint. You pointed me to the right direction.
Author Closing Comment
by:olaf_joerk
Got the right hint from Craig.
IT Degree with Certifications Included
Aspire to become a network administrator, network security analyst, or computer and information systems manager? Make the most of your experience as an IT professional by earning your B.S. in Network Operations and Security.
Use of TCL script on Cisco devices:  - create file and merge it with running configuration to apply configuration changes
As managed cloud service providers, we often get asked to intervene when cloud deployments go awry. Attracted by apparent ease-of-use, flexibility and low computing costs, companies quickly adopt leading public cloud platforms such as Amazon Web Ser…
Both in life and business – not all partnerships are created equal. As the demand for cloud services increases, so do the number of self-proclaimed cloud partners. Asking the right questions up front in the partnership, will enable both parties …
Both in life and business – not all partnerships are created equal. Spend 30 short minutes with us to learn:   • Key questions to ask when considering a partnership to accelerate your business into the cloud • Pitfalls and mistakes other partners…
Suggested Courses
612 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
