Python2.7:I need a script to cut and separate in 2 parts this delimiter :
I have 3 Gb combo list so need something faster,thank you
example:
john:john
maddie:12345
would be
john
maddie
and
john
12345
john lambert
john lambert
Walter RitzelSenior Software EngineerCommented:
The script would be very simple:
new_list = []
for item in list: # assuming that your 3gb combo is iterable
   names = item.split(':')  # break on the : character
    new_list.append(names[0])  # add in a new list the name before the :
    new_list.append(names[1]) # add in a new list the name after the :
Now, can you explain a little more what you mean by a 3g combo list?
Are you parsing HTML? If you are using beautiful soup, the code above should work pretty well, just replace the list by the result of the findall method.
john lambertAuthor Commented:
thank you...
Join & Write a Comment
Free Tool: IP Lookup
