Martin Campbell
Does Surface Pro 2 have a max broadband speed
Does the Surface Pro 2 (8GB RAM 256GB storage) have a maximum speed broadband that it can get? I'm paying my ISP for 400Mb but the fastest I can get is 284Mb average over a number of tests via a USB 3 to Gigabit adapter. Before this it was worse. I fought with my ISP until they diagnosed probable faulty cable from nearest junction box to my property. They replaced that cable. The Speed-tests-before-and-after-work-on.pdfSpeed-tests-before-and-after-work-on.pdftechnician's laptop showed close to 400Mb but my Surface Pro 2 only got 237Mb average. Upload gets 40Mb which is what I'm paying for. They blamed my "Plugable USB 3.0 Docking Station" so I bought a USB 3 to Gigabit adapter. Running speed tests on my ISP's own speed test site and leaving the docking station out got me to 284Mb average. So the question is does the Surface Pro 2 have a limit or was the technicians laptop wrong? Testing with other laptops gets worse results.
Part of the problem is probably rather the USB to LAN adapter. They are usually not as effective as internal LAN adapters. Besides that, with Windows 10 you must be aware that this OS uses the Internet a lot in the background. So speedtests won't normally give you a reliable readout. Make sure you have disabled or better removed all the unnecessary m$ store crapps and don't allow them to phone home.
how do you measure 'speed' ?
Look in Reliability Monitor and see if updates are happening to any great extent. Updates are not always running. Then run Speedtest.net to see what your actual speed is.
I'm with Virgin Media Ireland and here's where I test: https://www.virginmedia.ie/broadband/learn-about-broadband/broadband-speed-test/
Can you provide results from the test?
Hi John,
The results are in the click through on the 4th line of my question :-)
Hi Rindi,
How do I do this please?
remove all the unnecessary m$ store crapps and don't allow them to phone home.
You are getting updates roughly when I do and that does not significantly impede my performance.
I regard 1 critical error per work week as too much.
Perhaps look the errors and see if you can determine why so many. I cannot see from the picture but you may have driver or other errors causing the performance deficiencies
The phone home stuff only happens at intervals and, again, does not impede anything.
Hi John,
The highest of 3 tests on speedtest.net was 197.
Check the errors as I suggested and compare a different machine at the same time on the same network.
In the start menu you can right click the crapps you don't want, and if they are uninstallable you'll see an "uninstall" option. That's mainly for the facebook, twitter, news, candycrush crap. Those which you have tiles for you can right click and select "Turn live tile off", and you can also "unpin from start".
In "Settings" you can also turn notifications off, or in "Privacy" you can turn practically everything off.
Another thing you might consider with so many critical errors is rebuilding the machine.
Go to the Media Creation Link
https://www.microsoft.com/en-us/software-download/windows10
Click on Upgrade to Windows 10 (even if Windows 10 is running), click on the Download button, select Open (Run) but NOT Save. Allow the program to run. Allow drivers to update. Then select Keep Everything.
You do not lose anything, drivers are updated and you get a fresh start.
Hi John,
Only Sae and Save As come up. Open or Run don't show up!
I can't tackle doing this right now. However Virgin Media seem to be accepting that they need to do some more work. I'm away on business at the end of this week so aske them to come any day after 6th December.
Best to close this now and accept John's solution of rebuilding the machine with a Windows 10 ISO.
Thanks for the update and I was happy to assist,
