Solved
China bladeless fan : comment on quality & blowing strength & noise level
Posted on 2016-11-20
Last Modified: 2017-01-05
https://wholesaler.alibaba.com/product-detail/bladeless-fan_60293379192.html?spm=a2700.7782932.1998701000.1.IKa5L8
https://www.aliexpress.com/item/New-Design-Bladeless-fan-Electrical-No-Blade-Fan-Home-Appliance-electric-fan-cooling-only-AC220V/32706039409.html?spm=2114.40010208.4.9.ioIn4a
I'm contemplating Dyson's alternatives & looking at the above 2 items.
Q1:
For the top item, it says Supply Air Rate is 30L/S  while output is 450L/S (I presume L/s
means litres/sec) : how is it possible that input is not equal output ?  From physics
point of view, they should be the same, isn't it
Q2:
are the 2 items above the same item?  Bottom item did not indicate the measurement
/diameter of the fan
Q3:
Any tried them before & can comment on these bladeless fan's quality (breakdowns,
noise level ie should be quiet enough not to disturb sleep at night & the air flow could
reach say 4 meters away at top speed?)
Question by:sunhux
  • 2
  • 2
4 Comments
LVL 56
Accepted Solution
by:
Handy Holder earned 2000 total points
A1: Presumably 30L/s air is pumped into the ring and shoots out of the circular blade. This airflow pulls surrounding air along with it which creates a vacuum in the middle of the ring that pulls more air through the open ring. So 420L/s is drawn from the back to the front by the 30L/s that gets pumped through the ring. (I don't know if L/s is litres per second either but that's the principle behind a bladeless fan whatever the units, It's similar to the venturi blower except that uses compressed air at a higher pressure. In the drawing at http://www.ciecompany.com/venturi_air_blowers.htm the 420L/s is represented by the 3 arrows going through the back of the device.
I cn't help on Q2 and Q3.
Author Comment
by:sunhux
Thanks Andy.
Found a similar looking fan in amazon: many bad comments about it esp
the breakdowns, DoA & the noise level :
https://www.amazon.com/Bladeless-Fan-Adjustable-Multispeed-Mountable/dp/B008CVETUQ/ref=pd_rhf_yaod_p_img_7?_encoding=UTF8&psc=1&refRID=GZ7JZ0T9Z7XBZ6Z1D1M0#customerReviews
Probably I go with Lasco bladeless fan : tho it can't mount on wall, I probably can do a shelf to
let Lasko stand on it
Author Comment
by:sunhux
One last question:
For US-based electronics which use 110V, there are adaptors to use them in UK's 220V.
I got one such adaptor & the adaptor get so heated up (boiling water's point) ; is this
an adaptor issue or the electronic device issue?  Worried it will damage the device or
adaptor may explode
Would getting better quality adaptors help?
LVL 56
Assisted Solution
by:Handy Holder
I wouldnt trust an adapter, a transformer would be better but a lot biggerand more expensive.
2018 Annual Membership Survey
Here at Experts Exchange, we strive to give members the best experience. Help us improve the site by taking this survey today! (Bonus: Be entered to win a great tech prize for participating!)
Stuck in voice control mode on your Amazon Firestick?  Here is how to turn it off!!!
If you're a modern-day technology professional, you may be wondering if certifications are really necessary. They are. Here's why.
Finds all prime numbers in a range requested and places them in a public primes() array. I've demostrated a template size of 30 (2 * 3 * 5) but larger templates can be built such 210  (2 * 3 * 5 * 7) or 2310  (2 * 3 * 5 * 7 * 11). The larger templa…
Suggested Courses
601 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
