BISWAJEET PADHI
need summation of cells of the same row having same column difference between the two cells
i have a excel sheet having 1260 columns , and i need to add values of columns 1, 14 , 28,..... till 1260 in the multiples of 14.
is there any formula to add these columns with in single shot.
can't think of a way to do this if not using formula, but you can get a try using macro
You may try this....
In AVM2
In AVM2
=SUMPRODUCT(--(MOD(COLUMN(A2:AVL2),14)=0),A2:AVL2)
and copy down.
Subodh's suggestion will ignore column A as the result of MOD(A2,14) is 1 and then thereby not included in the SUMPRODUCT.
If you are including column A as col 1, the 14th columns thereafter would be columns 15, 29, 43, 57 etc
