Start Free TrialLog in
Avatar of GMartin
GMartinFlag for United States of America
will an outside wireless weather transmitter interfere with inside AT&T wireless equipment?
Hello and Good Afternoon Everyone,
         I recently purchased a clock which has several features.  One of its features is its ability to display the outside temperature.   In order for this feature to work, an exterior wireless sensor needs to be installed on the wall outside.  Before commencing the setup and configuration of this clock, I am wondering if the wireless transmitting sensor might potentially interfere with the wireless functionality of my AT&T equipment.
         Any shared thoughts or suggestions will be appreciated.
         Thank  you.
         George
Avatar of Jake Callander
Jake Callander
Avatar of GMartin
Hi
         Thank you for your follow up.  Seeing that the clock with the exterior weather sensor is new and all of the wireless AT&T equipment are working just fine, I believe everything will be just fine seeing they will be using different wireless frequencies.
          George
