I have to work on an android application using visual studio. So I started by writing a simple "Hello World" application to print on the console.
It gives the following error.
______________________________________________________________________________________________________________________________
1>------ Build started: Project: RestSharp.Android.Sample, Configuration: Debug Any CPU ------
1> Processing: obj\Debug\res\layout\main.xml
1> Processing: obj\Debug\res\values\strings.xml
1> RestSharp.Android.Sample -> C:\Data\Share\RestSharp\RestSharp\bin\Debug\RestSharp.Android.Sample.dll
2>Starting deploy VisualStudio_android-23_x86_phone ...
2>Starting emulator VisualStudio_android-23_x86_phone ...
2>C:\PROGRA~2\Android\ANDROI~1\tools\emulator.EXE -partition-size 512 -no-boot-anim -avd VisualStudio_android-23_x86_phone -prop monodroid.avdname=VisualStudio_android-23_x86_phone
2>PANIC: Cannot find AVD system path. Please define ANDROID_SDK_ROOT
2>Emulator VisualStudio_android-23_x86_phone cannot be started.
========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========
========== Deploy: 0 succeeded, 1 failed, 0 skipped ==========
After looking for "Cannot find AVD system path. Please define ANDROID_SDK_ROOT" on Google, I thought I may have to set up an environment variable. So I added thid to the Path list in System Environmental Variable "C:\Users\soume\.android\avd". However, the error has not changed.
Please suggest what is wrong and how to fix this issue.
Thanks in advance.
