Jeff S
SQL question - help with insert for missing info
I am having issues with a crystal report not displaying values, not because of the crystal report, rather the SQL is missing in my file to populate the report.
Essentially, what I need in my SQL are inserts to fill in the holes and looking for advice on best practice to do so.
In my report, I am outputting the following fields:
Patient Visit Charge
Patient Payment
Insurance Payment
Patient Adjustment
Insurance Adjustment
My output could have one of these or it may have all of these for a given month / Financial Class combination. If its missing any one of these, I need to insert the missing values and report specific values to it.
My report columns are as such:
Type , Amount , Action , Source , FinancialClass and Date
Table Structure of my temp table that's getting the records from my main query:
CREATE TABLE #Output
[Type] VARCHAR(5)
, [Amount] NUMERIC(10 , 2)
, [Action] CHAR(1)
, [Source] INT
, [FinancialClass] VARCHAR(60)
, [Date] DATETIME
Type will always be PA or C. PA for Payment or Adjustment and C for Charge.
Amount will be the sum of the transactions for the month for the unique Type, Source and FinancialClass.
Action with be either P for Payment or A for Adjustment. It will be NULL on Charges.
Source is either 1 or 2. 1 for Patient and 2 for Insurance.
FinancialClass will be determined by client system and different. Example (Medicare, BlueCrossBlueShield, Aetna, Cigna) ...
Date will be month date for the transactions formatted as such ( 2013-02-01 00:00:00.000 )
Sample output:
PA 25.50 P 1 Sliding Scale 2013-02-01 00:00:00.000
PA 2308.00 P 2 Medicare 2013-02-01 00:00:00.000
C 130.00 NULL NULL Commercial 2013-02-01 00:00:00.000
PA 1500.00 P 2 HMO 2013-02-01 00:00:00.000
C 130.00 NULL NULL HMO 2013-02-01 00:00:00.000
With the sample output, I would need to do the following inserts; again needing all 5 of the values to prevent holes in my data:
C 0 NULL NULL Sliding Scale 2013-02-01 00:00:00.000
PA 0 P 2 Sliding Scale 2013-02-01 00:00:00.000
PA 0 A 2 Sliding Scale 2013-02-01 00:00:00.000
PA 0 A 1 Sliding Scale 2013-02-01 00:00:00.000
C 0 NULL NULL Medicare 2013-02-01 00:00:00.000
PA 0 P 2 Medicare 2013-02-01 00:00:00.000
PA 0 A 2 Medicare 2013-02-01 00:00:00.000
PA 0 A 1 Medicare 2013-02-01 00:00:00.000
PA 0 P 2 Commercial 2013-02-01 00:00:00.000
PA 0 P 1 Commercial 2013-02-01 00:00:00.000
PA 0 A 2 Commercial 2013-02-01 00:00:00.000
PA 0 A 1 Commercial 2013-02-01 00:00:00.000
PA 0 P 1 HMO 2013-02-01 00:00:00.000
PA 0 A 2 HMO 2013-02-01 00:00:00.000
PA 0 A 1 HMO 2013-02-01 00:00:00.000
In my output, I need a record for all five transaction combinations (Charge, Ins Payment, Patient Payment, Ins Adjustment and Patient Adjustment) for the unique Financial Class and Dates. Again, 4 things could be missing or nothing could be missing, but if something is, I need to insert the missing values.
I hope I explained this well, if not, let me know. Thank you immensely in advance for any suggestions/help with the code for this.
Patient Payment
Insurance Payment
Patient Adjustment
[Type] VARCHAR(5)
, [Action] CHAR(1)
, [Source] INT
, [Date] DATETIME
Sample output:
I read the responses and it was Pauls comment about looking at the other query that engaged my mind - I took the existing and re-formatted it to do all my values differently. At the end of the day, I got my numbers I needed and info back as I desired. I will split points for those that took the time to look and attempt to help and offer suggestions and insight. Thanks again!!
Thank you for looking!
and setup your table here...
